shortlid wrote:So is 5X4.5 the same as 5X110mm? Also will the MANY wheels with 5-4.5 bolt pattern and 67 hub centric fit like the ones on Mopars like Sebrings, and Hyundais?
no 5x4.5 is not the same as 5x110our J30 bolt patern is 5x114.3 also know as 5x114 which IS the same as 5x4.5 (American) why cant we all just be metric lol the offset is some were between 35- 40 mm if i remember right if you go to tirerack.com it will tell you and yeah you can put any brand you want AS LONG AS the bolt patern,hub size, and offset falls in the range your looking for
but like i side Tirerack.com will be your best friend
