+1 or just go with a wide kit witch would cost more. your bullet. you shoot.FlatBlackIan wrote:Add negative camber, lots of it.
Looks amazing!drifter92 wrote:you are full of s***.
i just bought 15x8 / 15x10's for my S14 and they look amazing, your opinion doesn't change how the car looks to other people. You need to realize what you say doesn't become a fact just because you said it...
Fitting a overfenders/widebody kit only to run 195 width rubber?!TurboSauce wrote:+1 or just go with a wide kit witch would cost more. your bullet. you shoot.
I hope it turns out good for you. There's no need to worry about altering your fenders to accomodate this mexi-flush setup if the wheels are gonna get replaced anyways, right?drifter92 wrote:these only don't fit because i was sent the wrong offset, i am getting the right ones sent to me.
+2 and a hell of a pull if you really must run such a skinny wheel. but you said -25 offset? that looks about right according to that offset in that size wheel.... are you sure thats not the size you ordered? just take off the wheels dismount the tires measure the distance from the center of the wheel to the mounting surface if its not 25mm inward from the center of the wheel then its not the correct size.FlatBlackIan wrote:Add negative camber, lots of it.
Let's not forget that these are also 15 inch diameter wheels. That's even smaller than the stock diameter.phanatikz32 wrote:epic mexi-flush! man i'm not a fan of flush 8in wide wheels at all, seeing 8in wide wheels flush with the fender just looks sketchy.... i feel like if its less than a 9.5 then dont try to make it flush.... its like back in the late 90's early 2000 when spacing your wheels past the fender was the s*** for mexicans so you'd see hondas on stock wheels spaced passed the fender....
i know how to measure the damn wheels, i have -25 offset and i need +12 offsetphanatikz32 wrote:epic mexi-flush! man i'm not a fan of flush 8in wide wheels at all, seeing 8in wide wheels flush with the fender just looks sketchy.... i feel like if its less than a 9.5 then dont try to make it flush.... its like back in the late 90's early 2000 when spacing your wheels past the fender was the s*** for mexicans so you'd see hondas on stock wheels spaced passed the fender....
Modified by phanatikz32 at 12:15 PM 8/19/2009
I was thinking, if the OP thinks mexi-flush is the hot stuff... maybe it's because... he's mexican? I mean... it is Victoria, TX...
Not on mine. SE.drifter92 wrote:stock size is 15" dumbf**ki was sent the wrong offset and i will have the new ones in a week or so.
People these days are f**king stupid
you said you bought 15x8 -25 but then you said that the guy sent you the wrong size...drifter92 wrote:I bought 15x8" -25 Offset Wheels with 195/60 Tires and my wheels are too far out from the fenders...I will be getting lower profile tires for sure. What do you guys think i should do?
so all i'm saying is that these look like a -25 offset which is what you ordered so why not measure them to make sure they didn't send you what you ordered? if you ordered -25 and now realize you want a +12 then just say that. plus then you said this:drifter92 wrote:these only don't fit because i was sent the wrong offset, i am getting the right ones sent to me.
how does this even make sense if the guy you bought them from sent you the wrong ones?drifter92 wrote: i already have a guy that wants them from NY and the new ones on the way
