YESBubba1 wrote:I guess they suck because they're not "fun"?
Well, a complete moron would ignore checking the automatic transmission fluid when it is part of the maintenance program spelled out in the OWNERS MANUAL. Make sense buddy? So what if it's closed loop system?So are the oil , cooling, and air conditioning. All are designed not to leak,but at some point they might. If the owners manual recommends checking, you check it.PoorManQ45 wrote:What do you consider "spirited"?
Hopefully you're not getting mixed up between abusive and spirited. An example of the difference would be, abusive = dropping the clutch at peak torque RPM, spirited = shifting at redline.
The car WILL fail if you abuse it. If you drive spirited with no abuse(redlining is NOT abuse) the car should NOT fail. If it does, there is something wrong with one of the vital engine systems
Hello, Any car will fail if you abuse it enough. I didn't think it was necessary to explain the definition of spirited driving. But okay, how about "consistently operating the car harder than is neccessary".
It's a good thing that you don't need to check the LEVEL of the transmission fluid. Before for you go off, you have to remember that the transmissions fluid system is a CLOSED loop system. Not like the engine oil system. THe ONLY way for fluid to get out is through a leak. Unless you part on dirt, mulch, or grass you *should* be able to spot leaking fluid imediately. So no need to check the level of the fluid. And when you change the fluid, all you have ot do is measure the amount that came out, and that's the amount you should put back in.
I agree there are many subjective factors that go into vehicle ownership, but if you have access to unbiased source that shows you that all of the background, problem areas, reliability, owner surveys, are you saying you wouldn't want to review that before buying??Jesda wrote:CR's reporting is only relevant for anyone who expects their car to do nothing more than start, move, and stop. Sorry, I'll stick with Automobile Magazine's long term tests. Theres too many subjective factors in vehicle ownership and satisfaction to rank them the way you would a toaster.
LOL.MinisterofDOOM wrote:
YES
Dude, the oil isn't a closed system. Rings arn't a perfect sealBubba1 wrote: So what if it's closed loop system?So are the oil , cooling, and air conditioning. All are designed not to leak,but at some point they might. If the owners manual recommends checking, you check it.
Not true. VW does promote a "lifetime automatic transmission fluid"in their cars. Interesting thing is if you talk to mechanics that work on VW's, they'll tell you that in the fine print, VW defines "lifetime" as the end of the warranty period, not forever literally. The mechanics recommend changing VW ATF every 40K miles. Since it's an expensive task, budget conscious owners are not likely to ever change the fluid, which shortens the life expectancy of their very costly trannies. Another reason to consider avoiding used A/T VW's with over 100K miles.PoorManQ45 wrote:
I understand what you're saying though. Yes you *should* check the level of the transmission fluid, but if there are no leaks, then it shouldn't ever change
Good question. I had read somewhere it was made from pressed Siberian Yak bladders , but I believe it's actually some sort of patented synthetic formula. One would think the actual manufacturer of the fluid would offer an aftermarket version, but I'm guessing VW controls either the patent or owns fluid manufacturer and restricts production to just their brand. Dang clever way to force a dealer service relationship with owners.PoorManQ45 wrote:Bubba: Do you know why the VW transmission fluid is so expensive? Is there a reason for it, or is it just because no one else makes it and they're a monopoly?
By clever, I meant sneaky, not in a good way. Of course it would be better if VW charged less, but VW wants to make money. I don't blame them.PoorManQ45 wrote:No, that is not a good way to increase deal customer relations. I good way to increase relations would be to offer the fluid at a LOWER cost then any aftermarket fluids, this is assuming that there would be some.
That would allow customers to *choose* to go to the dealer of their own free will, not because they were forced to
