what rear wheel drive transmission fits an E15 series engine
Speeddoctor
Car: Nissans, Infinitis, datsuns, motorsickles,
NICO founder April 22, 2000
What rear wheel drive transmission fits an E 15 series engine? Thanks in advance.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
No way Doc.
You dont get to pop in here and ask a question like that without eluding to whatever wicked project you've cooked up now. Out with the details. I know there is awesomeness afoot. :gapteeth:
Hows life treating you? I think its time for you to update us on some of your current projects. :dblthumb:
krimsonviper
2006 Mazda 3i Sport -Totaled
1989 Nissan S13 -Sold
1990 Nissan S13 -Sold
Wait, this is THAT doc? The forum creator? The no avatar tossed me off. Pics of your vehicular shens are a must!
Razi
Car: Moo
Quick someone catch him!
nissangirl74
Speeddoctor wrote:What rear wheel drive transmission fits an E 15 series engine? Thanks in advance.
What's it for Doc?
Speeddoctor
Ah man!!!!!! Geez Louise.........I'm busted!!!! You all are too smart! Thats my guys (and Nissangirl74........) God Greg, you are so lucky.....
Flat black: Awesome avatar and pic...good call out.....on me....
Razi:.......funny and good call out
Nissan Girl74.........Thx for just bein nice and not Raz-in me (hee hee)....I can't say......what it is for......Been searching harrd...please someone help!
What auto or manual transmission (rear wheel drive) would bolt up to an E 15? Whoever gives me the right answer is my new hero.....for those who just want to raz me...(I like that too) Thx! SD
Dattebayo
I did some searching, and The '91-'99 RWD Serena van was available with the GA16DE in it, and the GA has the same bolt pattern as the E series engines.
It's a van, yes, but it's the only thing that will bolt straight up. Hope that helps.
Speeddoctor
thats very helpful......especially knowing the GA has the same bolt pattern. Thanks Dattebayo........SD
Chaotic_Warlord
Car: Black 5 speed Swapped 1995 240sx
I'm guessing you are working on making a RWD 310...?
First post of the new year....
Dattebayo
Nah, I'd rather guess a turbo pulsar E15ET in another older chassis...
Chaotic_Warlord
True, but he didn't specify if it was a turbo E15 or not.
Actually, nothing that I know of in Doc's fleet that's got an E15, so this must be a new acquisition.
The E15 was in the 82-85 Nissan Sentra/Sunny/Cherry/Pulsar quadruplets, as well as the (kinda rare) 310.
Same engine was present in turbocharged configuration in the Pulsar ET/EXA, and the foreign market Cherry Turbo, as well as something called the Langly GT/Sunny LePrix Turbo (aka foreign market B13 Sentras).
None of those cars are RWD, so it's gonna have to be a matchup, like Dave said, at the bellhousing.
EDIT: Dave's right - That Serena Van is likely to be your only good option unless you have an adapter plate made.
http://datsun1200.com/modules/mediawiki ... ngine_Swap
I'm betting you'll find some of these in Puerto Rico, where the locals make the 1200cc Datsun motor make a TON of power (170hp!!!) or just have one imported (I have a possible source, I'll check with him after the holiday if you want).
If you decide on the adapter plate route, Wes has some experience there.
nissangirl74
AZhitman wrote:None of those cars are RWD, so it's gonna have to be a matchup, like Dave said, at the bellhousing.
I'm guessing a transmission from a 210 would work, but I am only guessing because I do not know what it is going into. The motors are similar, the E series motors replaced the A series motors. Like I said, I'm guessing. C'mon Doc, I need more info!!!
Never mind. New info says that won't work. if it was an A15, it would work. :gapteeth:
Speeddoctor
You guys are great! Wow! OK...Ill come clean........Im just doing some long-term planning.......Im not happy with the running and reliability of the engines in my 63 pickup and 411 wagon.....so eventually...I want to make a change........Here are my choices...:
1. Build a killer A14 or A15 from a B310......side drafts high compression....that would be period....but reliability? decent supply
2. Use an ET 15 or ET turbo matched to RWD transmission.......(Good call by Dattebayo)...good supply of those
3. CA options...most available CA20....
4. SR 20DE supply: lots and lots thanks to G20
5. Z24 from truck
6. Ka 24 seems too big......27" high and 25"long....
I want nothing to do with having to hack and cut.......a lot want small....easy fit just want easy.....definately no turbo except if I used the E15......100-150 hp would be just fine.....want no hassle driving.....so i CAN drive them more!
PS: Im sorry ive been away......my life has been overwhelming.......it just hasnt seemed to let up........there are some changes im making..big ones..that ought to let me get my life back....Good news...my kids are great and my relationship with them is great.....
I love my Datsuns/Nissans..they are like my kids......Jon has my roadster and M30..... It has been great to see him enjoy them....now.....not after im in the grave...
Finally: I love you guys......( u know what I mean)......and I love to see what you all have made NICO into.....
Thanks! SD
PapaSmurf2k3
Site Admin
Good to see you again SD! Let us know what you decide :)
I'll have to disagree on the reliability and durability of the E1 in the 320. Mine has no problem with 55-60 mph, starts right up after sitting for 3 months, and gets about 25mpg (WAY outta tune). Those engines are bulletproof.
If it's more power and minimal hassle you're after, then I'd recommend an R16 (Roadster engine).
Beyond that, an SR20DE or VE makes sense, but the G20 does you no good there- you need a rwd engine. Problem is, the trans won't fit the tunnel.
In fact, and A14 / A15 swap won't help either - Trans is too big, you'll be cutting the tunnel. Plus, you'll have to have a rear end built, since the 5.xx rear end ratio won't play nice with the new transmission ratios.
If it were my L320, I'd hit up some of those Puerto Ricans in S Florida and have the E1 rebuilt. Those guys wring a TON of power out of Datsun engines.
For the 411, the answer is simple - Let my guy build you a stroked R16. We bored and stroked ours to a 2-liter for the WRL411 and it's awesome. That's 140+ hp with bolt-ons, and it's OEM. Easy fit and no one will know, since the 411 SSS came with an R16 from the factory.
p.s. Still shopping for a CSP311, almost pulled the trigger on one out of AU. Shipping was the kicker. :(
Razi
Car: Moo
Hahah.
I won't "raz" you anymore Doc. :gapteeth:
Speeddoctor
Hey Papa great picture.....Thx RAZ....
Greg I like your ideas.......You know the H20 is a 378cc stroker version of the R16 that is still being made for fork lifts.......I like that idea..but parts are hard to find...does the R16 bolt up to my 411 trannny? My roadster ran like a top......with an R-16.....
The Ricans are tuning the A-12?.......what are they doing? How much power? Happy New Year! SD
Speeddoctor wrote:Greg I like your ideas.......You know the H20 is a 378cc stroker version of the R16 that is still being made for fork lifts.......I like that idea..but parts are hard to find...does the R16 bolt up to my 411 trannny? My roadster ran like a top......with an R-16.....
Not hard to find at all. I have access to the crank, rods and pistons for a U20 (SRL311 engine) as well as a builder who's done over 100 stroked 1600's.
Your 411 has a J13, so I believe it will bolt up. But you'll want the ratios from the Roadster trans (which is no big deal, you'd get the trans with the R16 5-main when you decide to build a stroker).
nissangirl74
Speeddoctor wrote:does the R16 bolt up to my 411 trannny?
If you could find a SSS 411, the R16 is already in it. :gapteeth:
Speeddoctor
go ahead Nissangirl and rub salt in the open wound.......I was just getting ready to give the Silvia to you and Greg for christmas...but I see how u wanna play! hee hee sd
Speeddoctor
hey! u know how much I like those faces...wheredid they go?
If you want Kevin Desirello to build you a stroker, I'll tell him to start looking for a 5-main R16 and a 5-speed.
Then, you'll just need the special intake manifold and exhaust manifold (that lets the R16 fit in the narrower 411 engine bay). I know where a couple of those are as well.
I'd store the J13 though. Never know when you'll want to make it stock again.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Speeddoctor wrote:hey! u know how much I like those faces...wheredid they go?
After you hit "Quick Reply", hit "Full Editor". They'll show up on the right. :mike
nissangirl74
Doc,
Is your 411 a manual or an automatic?
Speeddoctor
yay! There are the faces!!! Thx ACE. ACE did u see the post I made to you?
Thx Greg......i would def. keep the original of what I take out......the R-16 idea is a good one......what compression does he usually set it up with?
Nissangirl......its a manual......... :bigthumb:
Whatever CR the flat-top pistons make... Not sure.
Engine size is increased from 1595 to 1982cc, a 24% gain. We also went with a custom-grind Isky cam with a healthy lope. VERY out-of-place in a wagon. :)
Carbs are from a SRL311. I run Premium in it.
Speeddoctor
awesome.
So, does that mean you;re actually gonna get 'em out and drive 'em? ;)
Bex and I just drove the 311 and the 411 this morning, about 60 miles round-trip.
nissangirl74
When we left the house, we could see our breath it was so cold. I drove the 311, top down. Hey, with thick jeans, two shirts, two coats, gloves, and the heater going, it wasn't half bad! ;)
