what power with Vh45de
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
Mattbacon
hi im just in the finishing processes of transplanting a Vh45de into my car
what im wanting to know is what power are sum of u guys making with basic N/A setups, with mild mods
im new to V8's and N/A
so im looking for a good way to setup this motor to get sum more power, before looking to a turbo, or maybe supercharged setup
cheers for any advice
matt
Ezekial
Car: 2001 Nissan 200SX S15
this wont help ... but turbo it straight up ... and welcome 600 rwhp
Mattbacon
which leads me to ask
with correct fueling and stock internals,
what HP have u guys reliably run? (as in street driven)(even with turbo setups)
but i wana try get sum N/A HP first before going for turbo setup
John Dixon
Car: 300ZX-TT Z32
I'm currently building mine up with 98mm bore (5.0l), 11.2:1 CR, flowed heads, custom headers and 8x45mm throttle bodies. Hoping for over 450bhp, but time will tell ...
Ezekial
John Dixon wrote:I'm currently building mine up with 98mm bore (5.0l), 11.2:1 CR, flowed heads, custom headers and 8x45mm throttle bodies. Hoping for over 450bhp, but time will tell ...
you should get a billet stroker crank with me ...
so you bored each cylinder 5 mm?
John Dixon
Car: 300ZX-TT Z32
Ezekial wrote:you should get a billet stroker crank with me ...
Yes, 5mm overbore. Too late for the stroker now, committed to this route. Rods / pistons are made, it's all being assembled.
Ezekial
5 mm is a fair overbore!!
would have raised the compression over 11.0:1
hmmm ... might give that a go ... 5 mm overbore and run 3.5 mm thick head gaskets to achieve 9.0:1
Mattbacon
has anybody got a simple setup like exhaust, headers, new intake
minor mods like this, what sort of power?and also has sumbody had a stock VH45de powerd car on a dyno?
is 200+kw wheels easy to achieve with N/A motor?
Ezekial
the guys on here reckon the exhaust system is close to spot on ...
send your cams to tighe
John Dixon
Car: 300ZX-TT Z32
If you want the gaskets made, can probably get them done for you, as the guy who did mine will obviously have the pattern. Aren't you worried about the big squish clearence with thick gaskets.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
John Dixon wrote:If you want the gaskets made, can probably get them done for you, as the guy who did mine will obviously have the pattern. Aren't you worried about the big squish clearence with thick gaskets.
Not to mention timing change. Why do people think thick gaskets with boost are viable?
John Dixon
Car: 300ZX-TT Z32
Actually, Escort racing do low comp pistons I think, will try to dig out the link for them. They also do Hi comp ones for NA builds. Pricey though
Mattbacon
i have to do a new exhaust anyway, no choicei put the engine into the car, it is not a Q45 car
so i need a custom exhaust, i wana find a good size (for N/A at this stage)
i will turbo it (or supercharge) later on, but want to run N/A first, learn the car, get all the susp + breaks ready, and Certify the car so it is road legal
and im not in the USA by the way
cheers
p.s. anybody had a stock vh45 on the dyno? or a mildly modified one? exhaust, maybe cams?? sumbody!?!?!
Ezekial
i really cant see it being a problem since i have full control over ignition timing, cam timing, VVT, etc
Its called an aftermarket ecu and a set of adjustable cam gears if necessary
John Dixon
Car: 300ZX-TT Z32
Here's the link to escort if anyone's interested. They do low comp forged and hi comp cast pistons for the VH45/VH41http://www.escort-us.com/
Mattbacon
so nobody has put an exhaust on a q45 aznd dynoed it? or dynoed a stock vh45de??
sumbody must have???
Q45tech
90 Q stock with JWT ecu reprogram ~~240-250 R WHP and 250-265 R lb/ft.
In a lighter car the cams are wrong..............anyway 330-337 gross lb/ft [JWT ecu] is quite decent for a 4.494 liter even today. The brand new designs can't make that much.......because they are tuned for the HP race numbers for marketing confusion.
The exhaust manifolds are quite good compared to any factory supplied units..........even exotics.
The problems are that the engine was tuned [cams/runner lengths-diameters to plenum] to produce peak torque at 4,000 rpm.........vvt shifts at 4600 rpm............keeping a 4300 pound car with fuel and driver and AC on smooth up a hill with a 2000 rpm @60 mph requires some low rpm bias as the load could be 5,000 pounds with fat excecutives and their luggage from airport.
The driver was expected to act as body guard so some heft was required to fill the job.
Mattbacon
hmm thats sound almost 200KW with and exhuast, thats where im hoping for
i may have to change EX manifold to make it fit
if i do i will probably go straight to turbo, so probably another 2-3months of work,
but hopefuly it will fit, and be NA for ahwile
John Dixon
Car: 300ZX-TT Z32
Stay NA, sooooo much nicer than turbos
Mattbacon
but 200KW wont be enuf for long at all
i want well in excess of 300RW KW
so i think turbo wud be a good way to go
Ezekial
the only way to go
Mattbacon
so no dyno's??!?!!?
sumbody must have been on one!!!
New Jersey
Car: 1997 Infiniti Q45
1990 Nissan 300ZX
zombie thread.
i wanna know too.
hannibal
Car: Red Line to Glenmont
New Jersey
1990 Nissan 300ZX
not bad.
whats this nico ecu mentioned in there?
and for f*** sake when is someone gonna knockoff the mazworx header????
Return to “VH45DE / VK45DE / VK56DE Forum”
