vh45 s14 dyno
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
gs14racer
a little disappointed
ShionS14
Car: 2003 Saab 9-3, 2005 Infiniti FX35
well considering the stock q45 made only 278 hp at the flywheel, i would say that is pretty good. now you can look into an ecu tune and maybe some cams.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
275 WHP assuming 20% drivetrain loss. Over call it 325HP, pretty good considering its a stock motor with just a MT and headers...
of course, we all know that the stock VH45s didnt put out the mere 278HP, more like 300 stock.
Mettler
Car: HR31 GTS-8 coupe, VH41/45 Hybrid Transplant
Nice, now with a badass tune to lean that fuel mixture out a bit (the majority of the rev range under high load appears to be at 10:1 A/R), and advance that timing, and no reason why you can't easily get over 300whp. Then just slap in some cams and prepare to be blown away!
gs14racer
the richest it recorded was 12.2 via tail pipe probe
gs14racer
plus it was 103 degrees in the dyno bay
Mettler
Interesting that the measured results from your exhaust don't match up with what the ECU has in the maps (which is what I was referring to, not your dyno A/R results), unless I'm missing something here?
Florida240sx
Like the torque What you have done to yours? What was compression on it?
hannibal
Car: Red Line to Glenmont
250 lb-ft at 2500 rpm?? Not bad!!
saw your second youtube vid. Love the sound!
gs14racer
all it has is intake headers and exhaust.
hopefully ill be able to pick up the nico ecu soon and go back to the dyno on a hopefully cooler day.
ShionS14
any chance we could get some more video?
gs14racer
soon as i dont have a camera i have to borrow one.
CleanSfourteen
Car: A cooler car than yours
elwesso wrote:275 WHP assuming 20% drivetrain loss. Over call it 325HP, pretty good considering its a stock motor with just a MT and headers...
I agree, I think you're seeing pretty predictable numbers. And it must be fun to drive, it sure looks/sounds cool. You know it's not a KA or SR when you hear it
Florida240sx
What year is that motor?You replace anything on the engine? Timing chains, guides, water pump... How much it cost?
David Steele
Car: S13 FastBacK
I only go by what comes out at the wheels. Not assuming losses.
Mettler
That's all well and good but a simple difference like final drive ratio can change results, that's why it's therefore more intelligent to go by flywheel HP outputs, because then you actually analyse what type of power & torque the engine itself is putting out.
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
I would say that 275 rwhp is great for a VH45 that has not been tuned for max power. There is still a lot more to be had with some tweaking. The pull of the VH45 in my Q is awesome. I can only imagine how nice it is to have the same power minus 800-1000 lbs. Great job, bro.
So, when are you going to boost it? Every psi will give you approx. 20 hp with a properly designed system.
trix
Car: S13U CA18DET
Mettler wrote:That's all well and good but a simple difference like final drive ratio can change results, that's why it's therefore more intelligent to go by flywheel HP outputs, because then you actually analyse what type of power & torque the engine itself is putting out.
The final drive ratio has got nothing to do with the measured power output. As the power output is calculated from the tourque relative to the revolutions on a driveshaft/wheel.. Change the drive ratio, and the torque and revs. changes. Less rev = more torque. Or the other way around. The amount of power, hp or watt, is equal. If i'm not reading the laws of physics wrong that is.
Mettler
It doesn't really matter. You could put two identical engines in vastly different cars and get totally different readings at the wheels for each car, despite the engines producing the same results as each other if set up on an engine dyno.
Reno
Car: 89 S13, boosted.. RAWR..
dual t28's @ 15 psi? :P 9:0:1 compression?
/ ThreadJack
Florida240sx
Reno wrote:dual t28's @ 15 psi? :P 9:0:1 compression?
/ ThreadJack
Dual t3/4's
Reno
hmmm sounds alot better hey you gonna do the VH Swap??
i just got a new job and im gonna save for the VH xD just wonder where can i get 1
David Steele
Car: S13 FastBacK
Like I said I only go by what comes out at the wheel.
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
I don't go by wheel or flywheel hp so much as mph in the 1/4. A loose torque converter WILL throw off dyno numbers a bunch but that won't be reflected in track ETs.
David Steele
Car: S13 FastBacK
ScottJackson wrote: A loose torque converter WILL throw off dyno numbers a bunch but that won't be reflected in track ETs.
Then fix your loose torque converter?
ScottJackson
ha ha! Of course I mean a higher stall converter. Any torque converter will affect wheel horsepower numbers but a high stall one will affect it more. A lot of people think this drop in rwhp numbers means the auto trans is "soaking up" a lot of power, when it's actually just the dyno reading higher engine rpms than what's being transmitted to the transmission itself. The acceleration of the car is what matters and this lower rwhp number from the dyno doesn't directly correlate to lower trap speeds.
autoworkz
Car: 450sx
well, these "ARE" DYNOJET numbers (also known as a random number generator) considering that dynojets read anywhere from 10-15 percent high, I think you are about right on. We got 257rwhp with no exhaust and like 270 something tq, but we had also played with the tune a little , got the nast dips out of the top of the graph. we actually had 225 ft/lbs tq at 800 rpm. cooky motor
Return to “VH45DE / VK45DE / VK56DE Forum”
