jr_ss »
https://forums.nicoclub.com/jr-ss-u34795.html
Sun Jan 04, 2009 1:32 am
This might be of some use to you...
I talked to Scott at Enthalpy about breaking in the motor. I didn't ask him what oil or viscosity to use on initial break in, but what he did tell me was about the actual break in itself. He said run it for 20-25mins in neutral at 2000-2200rpms. You can do it up on jack stands or on the ground, which ever suits you. During that time, check for leaks, fix any problems and so on. Breaking the motor in this way allows for high vacuum conditions which helps seal the rings to the wall better. Running it at speed helps the rings break/wear into the hone, as idle speed doesn't allow the rings to wear into the hone correctly, possibly creating blow-by and what not. Once this is done, change oil and filter and drive. You don't have to drive 500 miles for breakin procedures like back in the day. You may want to down shift and engine brake coming to stop lights or slowing down for the first 500 miles or so to ensure the rings are fully worn into the hone.
Hope this helps, it was a good bit of information that he sent me. I've read a few articles based on the same break in style and after pulling the motors apart from a season of racing they looked brandnew inside from using this break in method.
