Me.
Thanks V
Thanks for the explanation and clarificationVStar650CL wrote: ↑Mon Jun 20, 2022 5:10 pmThat means the Wix 57356 or 57356XP should both work fine for you.
Vstar
Costco full synthetic oil is cheaper than most conventional oil‘s so cost is really not an issue at all if you want to go with synthetic. There is no reason not to use synthetic oil.nabril wrote: ↑Wed Jul 13, 2022 8:59 amVstar
This thread convinced me to upgrade to a better filter, and I've got the TG and XG7317 in my amazon cart. Cool.
Now, to the oil. I've been using conventional Castrol on both Rogue's since the purchase, and changing the oil and filter every 5k just because the cost is not that much; I used the regular and crappy Fram 6607 and castrol regular 5/30.
My plan moving forward is to change the filters every 10 or 15k, and to change the oil every 7k or 10, but what oil should I get? Should I stay with conventional or is it worth it to switch to synthetic? My rogues are at 45k and 72k miles, and I don't know if switching to a synthetic "makes sense" or is smart, or whatever. More than likely, the cost of the oil will play a role, sure, but based on previous posts, the cost difference between synth and conventional has shrunk.
What say you?
thank you Kings, and I understand your argument for synthetic oil. I'm not concerned with freeze tests, living in Miami, but what you say makes sense.II Kings 9:20 wrote: ↑Wed Jul 13, 2022 9:45 amCostco full synthetic oil is cheaper than most conventional oil‘s so cost is really not an issue at all if you want to go with synthetic. There is no reason not to use synthetic oil.
Costco, Amazon, and super tech are all made by Warren out of Oklahoma and they’ve been making oil for 100 years. They perform quite well in testing. Not that you asked, but I’m not a fan of Castrol. Pennzoil platinum in one test was second only to Amsoil which finished first. I’ve never seen Castrol or even Mobil One do much better than mid pack testing. Oil is like religion, it’s probably not worth mentioning one’s brand belief.
You’re welcome. I love this guy’s videos. Some (Mobil 1 fans) would argue that his testing isn’t “scientific” but it is fair, consistent, and reproducible and I think it’s scientific enough. https://youtu.be/TWuKvnCq1jsnabril wrote: ↑Wed Jul 13, 2022 10:11 amthank you Kings, and I understand your argument for synthetic oil. I'm not concerned with freeze tests, living in Miami, but what you say makes sense.II Kings 9:20 wrote: ↑Wed Jul 13, 2022 9:45 amCostco full synthetic oil is cheaper than most conventional oil‘s so cost is really not an issue at all if you want to go with synthetic. There is no reason not to use synthetic oil.
I will look at Amazon, Amsoil, and Pennzoil.
Thanks again
I just found a gallon of Amsoil on Amazon for $104. Is that supposed to be cheap?II Kings 9:20 wrote: ↑Wed Jul 13, 2022 10:20 amYou’re welcome. I love this guy’s videos. Some (Mobil 1 fans) would argue that his testing isn’t “scientific” but it is fair, consistent, and reproducible and I think it’s scientific enough. https://youtu.be/TWuKvnCq1js
That’s balls expensive. I love Amsoil and just changed my honda CVT fluid with Amsoil. For the money and quality, I use penzoil platimum. It runs $23 for 5 qts on Amazon. It’s so close to Amsoil that it’s not worth the extra coin. The pic is from Amsoil so someone on Amazon is committing robbery without a gun.nabril wrote: ↑Wed Jul 13, 2022 10:32 amI just found a gallon of Amsoil on Amazon for $104. Is that supposed to be cheap?II Kings 9:20 wrote: ↑Wed Jul 13, 2022 10:20 amYou’re welcome. I love this guy’s videos. Some (Mobil 1 fans) would argue that his testing isn’t “scientific” but it is fair, consistent, and reproducible and I think it’s scientific enough. https://youtu.be/TWuKvnCq1js
I agree, for the money Amsoil is just too expensive maybe if I were racing or doing 20,000 mile intervals perhaps. Pennzoil platinum is so good that there’s no need to spend all of that coin on Amsoil.D1dad wrote: ↑Fri Jul 15, 2022 9:48 amSkip the amsoil, at least for motor oil. You really need to run it for an extended time to make since of the price. Now I do use their severe gear fluid in the wife’s rogue which is as reasonable as anything else. I’m still working through a couple hundred quarts of everything from valvoline to castrol to ravenol. Once those run out, if I’m still alive, I’ll probably double up on mobil1 every year when they offer their rebate. Assuming I’m not forced into an electric car.
It costs $22 today. Damn I should have bought it yesterday
Yes Casper and sorry.
