What kind of oil weight and viscosity is in your sr ??
n_bushaw
Car: s14 Kouki Silvia , 04 Subaru WRX with hybrid swap
I have read the fsms and know what all the numbers mean so dont try to be a d!ck. i am using 10w-30 i was thinking about using 10w-40 or 50 my car wont be driving in cold temp eather.what are u running?
SpeedRacer1
Car: 1990 240SX, G35
Ive run 15W-50 in Summer just fine.
Edit: "15W"
Modified by SpeedRacer1 at 6:25 AM 3/10/2007
spider_slayer
Car: S14 240SX
S13 240SX
mobile syn 20w-50 here
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Would you want to run a higher or lower W in the summer??? Would 5w20 be better in the summer or winter on a sr?
ho1ywars
your sr should never see 5 w 20
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
AmoebAssassin
Car: 1991 Base fastback 5spd, black
15W50 Mobil 1 full syn. I wanted to switch to 10W30 for the winter, but never got around to it.
jr_ss
Car: 95' S14
What oil actually came in and is recommended by factory to run in the car? I'm just curious, but I'll be running 10w-30 in mine.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
I run 10W40 summer, 10W30 winter(low boost) always AMSOIL
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
9240sx wrote:Would you want to run a higher or lower W in the summer??? Would 5w20 be better in the summer or winter on a sr?
The higher the weight in the winter will cause issues as it is already very viscous and the winter aspect will just add to that. Oh 10-30w.
n_bushaw
i will post a image from the fsm for s14 silvia
ILikeMy240sx
Car: SR Power
ho1ywars wrote:your sr should never see 5 w 20
Try living in MI for one winter.
During the winter time it easily goes below 0F numerous times. So during the winter times, I run 5W-30
During the summer time I run 10W-30
pearlS13
Car: 90 240sx
5W50 Mobile 1
ho1ywars
its a water cooled engine, so theoretically it should run the same temperature all year round. 5w30 all year round
switch to synthetic if you know your engine has low miles. it wont thin out as much as regular motor oil
i run 5w30 royal purple
DJ Cool Breeze
Car: 92 Nissan hatch w/ a blacktop Sr20 in it
10-30 year round..i live in va so it does not seem to get too hot or really cold
plus its the recomendrd oil to use by nissan
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
10w30 Mobil 1 Full Synthetic all year. You shouldnt have to run thicker oil in the summer for a couple of reasons. One, the thicker oil wont get picked up properly. Could cause bad oil pressure and detroy the motor. Two, if you think your oil temps are too high then you should think about getting an Oil Cooler. Send Enthalpy an Email sometime. He can explain everything in more detail.
HPR
Car: 1990 Nissan 240SX
I've been using Mobil 1 synthetic 0w50 all year long. Both for daily driving and on the track. No problems the past 2 years. I do change my oil religiously though. Whether it's -30 or +30 outside it works great. 75 psi under load at WOT and around 12.5 psi at idle after full warmup.
DuckyD
Car: 1995 240SX
I'm about to give the Greddy Oil a try. Getting a case for pretty cheap, I think it's 5w-40.
I have been using 10w-30.
