nlzmo400r wrote:how long does a sythetic blend of oil last, 45oo or so? i figure if full sythetic last 6k and regular oil is 3k, wouldnt a blend inteween
this depedns on so many factors. the amount of blowby you get, hiway vs stop/go, the gasoline u use, etc etc
genralizations are always fraught w/ risk.
I saw a UOA were a non syn oil had depleted it's TBN in 2500 miles, so it had probably needed changing at 2000.There are some syns that dont stay in grade after 5000.
As a rule of thumb yes you can run syns longer that regular oils but you will still see contamination happen at the exact same rate.Keeping u from taking fully advantage of its longevityAlso even if the base lube is good for 15,000 miles (and some are) the additvives are likely to be depleted long before then.
If I was using a non syn I'd change at 3k and at a full syn with a premium filter betwenn 3200 and 4000 miles depending on how much hiway driving I do.I once ran 6700 miles on one oil change ( MOBIL1 15w-50 w/ premium filter) but that was <pure hiway driving done in 3 weeks.
many will argue and perhaps rightyl that u can run longer.But when toital car ownership is so expensive an extra do 2dollars per month that it costs me to go with 3 k oil changes vs4 k oil changes is well worth it.
Besides the sharp eyed reader will notice all the recent sludge problems in engines thought to be good engines...You guessed it the manufacturer recommends 7000 mile oil changes for them and people actually followed it.
Fred...
