i have been looking al over for that answer...johnny_d wrote:Welcome! To answer your question, +35mm should flush if u don't drop it, search bud, search.
ll a 38 offset tuck it just inside the wheel well?johnny_d wrote:Welcome! To answer your question, +35mm should flush if u don't drop it, search bud, search.
Offset dictates how a wheel sits in relation to the hub. Factory wheel offset is determined by the location of the center line of the wheel bearings.XxXSnake23XxX wrote:Can someone explain to me what an "offset" isi want to get some rims for my sedan but i honestly dont know where to start
That's not correct! Its actually more correct to use the terms higher + offset and lower + offset. No one on this forum would be using negative offset wheels. those are only for RWD cars. But aside from that, D-Roll, you've got the concept reversed. The more positive the offset, the further the wheel will tuck into the fender. The less positive the offset (or the lower the offset), the more the wheel will stick out. we've covered offsets at least 10 times on this forum.D-Roll wrote: You've probably seen wheels that stick out past the vehicle's body (positive offset), and others where the center is nearly flush with the outer portion of the rim (negative offset). While they may have the look or style you desire they may also shorten wheel bearing life.
OK, I've seen +35 and +38 offset 20 x 8.5 inch wheels on a car, and I'll tell you, NEITHER OF THEM, will tuck under your fender if you drop your car. You will get rubbing if you drop your car with either setup. You see it actually gets a little complicated, but many factors are involved. 1. tire width (big difference in 245 wide tires vs 225 wide tires)2. rim width3. rim offset4. factory distance of wheel hub to fener wallt2thajfolife wrote:will a 38 offset tuck it just inside the wheel well?
yes, with that setup, your tire will only stick out 10mm more than stock, you should be fine with a drop with this setup.dangeris wrote:ok...so 20x8.5 with a +35 offset won't work but I would suspect a 20x7.5 would with a +45 offset wrapped with a 235/35R20 tire since that size is very very close to the dimensions of the stock tire.
IF you look closely at his setup, looks like he's running a staggered setup. The front don't look as deep as the back ones do...AkAd3MiKs wrote:do you guys know what size rims and offset this coupe has? Look at the rear wheels, I want my rims to have a deep dish like that. Thanks.
That is not the offset...that is the configuration of the lug nut holes.johnny_d wrote:5x114.3
for 18's, these are the following diameters of various tire setups, keep in mind, stock tire diameter is 26.3"mazda2005 wrote:Whats up RJ, I have a question about tires. I was just looking around and saw a rim i liked. The dimensions are as follows 18x8 5x114.3 ET40. Would you happen to know the proper tire size without messing up the speedometer too much. Tirerack suggested 225/45 R18 or there is a better match?
Thanks
would it clear if you drop??? maybe! would it clear if you drop and hit bumps... I doubt it!!johnny_d wrote:Yo, Robert!
I just bought some 19s wheels. Yes i know tires cost a ton but four brand new RH forged wheels (R7) for $650 I couldn't resist. Would have loved to get the RH R5 but they were not the ones being cleared out. Aniway, they are 19x8 and 235/40/19 tires were not available so I got the next best thing 245/40/19. Offset +38. Should that clear if i drop it?
I asked a guy at ravspeconline.com since they sell these wheels. He wasn't sure but said that you wouldn't want to run a staggered setup on this car. He recommeneded running a different disk sizes, the inner curvature of the of the rim. I'd never heard of this but I guess you can custom order the WORKs rims like this. I really like they way that car looks with it's wheels except I'm only looking at a 19x8.5...AkAd3MiKs wrote:do you guys know what size rims and offset this coupe has? Look at the rear wheels, I want my rims to have a deep dish like that. Thanks.
Sertelegger,if you plan on dropping your car, then the +45's will be PERFECT! Only thing is, they will be tucked under, so if you want the flush with fender look, then you could still get these wheels, but you could use like 3mm or 5mm spacers and get it exactly as flush as you want! Remember, it's easier to get higher offset wheels and then use small spacers to make them stick out a bit more (like Eric did). But you can NOT get lower offset wheels, and then say, oh s*it, I wanna drop the car but my wheels stick out too far! In that situation, you're just SOL!Sertelegger wrote:Thanks guys, this thread has really helped me to understand what all those numbers on wheel specs mean. I had a basic understanding before, but now I definitely understand that bigger isn't always better
So now I have two questions:
1. I understand that when people say +1 they mean a one inch bigger wheel size. But what is the baseline for that? 16"? My Altima 3.5 SE came with 17s, is that already considered +1? I am asking because those AP breaks on the Stillen website say "+1 required" to fit them, but it's not immediately clear to me if that means 17 or 18? Just asking out of curiosity, since I'm planning to get 18s I should be fine either way.
2. I'm somewhat of a Nismo nut so I was looking at the Nismo alloy wheels for the Altima, here the specs copied from the website:# 18x8.5# 45mm offset 5 lug# Fits OEM tire size 245-/45R18 (3.5L) or 235/45R18 (2.5L)a) Most people here were talking about offsets between 35 and 40mm, but these wheels have 45mm, which almost sounds like it is too much Is that what the stock wheels have?b) On the website it says for 2002-2006 Altima, can someone explain to me why those wheels would not work/fit on a 2007+ Altima?
Bonus question: Are black wheels on a black Altima really played out? I've been playing around with the TireRack website to preview different colors on my car, and somehow it looks pretty dark if everything is black, but I'm also not too much into the silver ones either. Maybe some gunmetal gray will do for me?
I'm with Doc! Until other people start making your car payments (if you have them) who cares what they say. It's YOUR car so make it YOUR car!!!rjdmmfl1 wrote:As far as black on black being played out, nothing is EVER played out if YOU like the way it looks. You may get people that say they don't like it, but hell, its not their car. Just because someone else doesn't like it doesn't mean they are played out. Its all about you getting what YOU want, screw anyone else that complains about your choice in wheels.
