What is grabbiness of brake pads ?
suzonka
Centric Premium Ceramic (301) Brake Pads
Shimmed to eliminate noise and vibration.
Positive molded.
Specialized ceramic friction formulas provide excellent stopping power.
Ceramic friction compounds provide extended pad life.
Linear response both cold and hot; never "grabby".
Low dust formulations keep wheels clean.
100% Asbestos-free formulas.
Scorched for improved bed-in.
Centric
Economy
Daily Driver
HP/HD
C-Tek, Premium
Posi-Quiet, Extended Wear
StopTech, Fleet Performance
frapjap
'07 Subaru Legacy
Howdy!
I'd like to try and help or agree, or disagree, or something with you, but I'm not sure what you're trying to tell us here. Is it related to your other thread about your Pathy?
brakes-grab-after-new-rotors-t593738.html
PapaSmurf2k3
Site Admin
"Grabby" refers to initial bite.
Some crappy pads (and brake systems in general) have WAY more stopping power when the pad is cold than when hot, and some brake systems seem to apply the brakes before you really feel much/any pressure in the pedal. Those 2 things combined make the brakes seem "grabby".
On the opposite side of the spectrum, if you have a system where you'll start to feel pressure in the pedal, and only slight braking is occuring, but brake force increases proportionally with pressure (and doesn't change as the pads heat up [within reason]), then you'd call that a more linear response.
frapjap
'07 Subaru Legacy
Thanks Papa. I didn't read that as literally as I should've.
