brakes grab after new rotors
suzonka
I have a 03 4 wheel pathy last year I had new rotors put on, they said my pads were still good . now Im getting a grabbing at low speeds to a stop my brake peddle isn't pulsating at all. the grabbing is annoying at times, I looked at the pads and they look like they are worn yet not to the little spring sensors on them . so if I put A grad a new set of pads on will it be smooth again?
frapjap
'07 Subaru Legacy
A new set of pads will certainly rule out whether or not you have a pad or rotor problem.
Typically, when you put on new rotors, new pads should go on with them.
suzonka
Thanks, If I replace the pads with new ones should I get the ceramic type and I cant turn down the rotors , so do you think it will still let me know if it was my pads being very used
frapjap
'07 Subaru Legacy
If you want to rule out any other potential problems, I'd do new through out- rotors and pads.
I personally don't turn rotors since they're usually cheap enough to buy new. However, most NAPA stores will turn a rotor as long as they're not in awful shape. Most folks find success there.
Not all pads are equal. Some ceramic are great, others can break or run down quickly. I typically go with the middle of the road option on daily driver commuter cars.
suzonka
frapjap wrote:If you want to rule out any other potential problems, I'd do new through out- rotors and pads.
_________________________________________________________________________________________________________________________
oK I was going to get the middle priced pads, they come in organic , than semi metallic and ceramic
why is it today everything in OEM is ceramic yet the non ceramic pads they say are equal or out perform the OEM pads/ :facepalm:
