freakyjason wrote:Right, well on these units (and i think in most cases) air fuel is measure x parts of o2 to 1 part fuel. The 1 part fuel is always assumed. However, i am not reffering to air fuel. I am talking about just O2. The apexi turbo timer that i have has just an O2 meter on it as well as an air/fuel meter. When on this setting it reads about 1.7 when warm. I'm not sure if this is voltage because from what i've read these numbers wouldnt make sense. Isn't O2 voltage measured from 0 to 1v, 1v being rich, 0 being lean and somewhere in between (maybe .5) being ideal? I'm really confuesed by this stupid thing and am inclined to believe that it is wired inccorectly.
You are correct, Nissan's do indeed use a nernst cell o2 sensor that reads 1 volt for rich, and 0 for lean. I didn't think about that, your readings could not be voltage, it would have to be some other reading. Without knowing what those numbers are actually referencing, its hard to say if the readings are good or bad. Do you have the instruction manual? Either check that or the companies website, it may be a percentage reading, I'm not sure, and I'm too lazy to do the math. I have a wide band sensor and gauge, and at idle I read near stoich at idle when warm, and around 11.5 when cold.
