what intake to buy?
rocket69GTP
Car: 2008 Infiniti G37
2005 Pontiac Grand Prix Comp G
wig wrote:I ordered the Stillen Gen 2, didn't want any cutting or drilling on my new G37. I should have it on Thursday and will do the install on the weekend.
Wig :biggrin:
Did you go directly through Stillen to order yours?
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
the Gen 2 doesn't require any cutting Joe.
The filters on that R2C look funky, but the tubes are nice...
Really any intake design similar to this will do great.
The reason people get an intake system is A) want a nicer sound B) want the extra 3-9 horsepowerz, and C) not having to constantly buy air filters
gcirillo
Car: 2009 G37 Convertible
I would favor the long tubes because they clearly draw air from outside the engine compartment. Filters that sit inside the engine compartment (and do not use an enclosure and snorkle like the OEM air boxes) are sucking in hot engine air which limits any HP gains, especially in traffic.
joe603
Car: 2014 Durango R/T
gcirillo wrote:I would favor the long tubes because they clearly draw air from outside the engine compartment. Filters that sit inside the engine compartment (and do not use an enclosure and snorkle like the OEM air boxes) are sucking in hot engine air which limits any HP gains, especially in traffic.
When you sit in traffic...do you need the HP? There is a common misconception when it comes to intakes. The reality is that when you accelerate, the underhood temps go down drastically in seconds. The only issue is if you drag race, sitting in the staging lanes it can heat up the intake track and you make less HP...but a long tube design would be even worse.
Just think about this...what's easier to drink from: a short, thick straw, or a long, thick straw with a few curves?
Poyzinous
good job joe. Another thing I tell people, is they don't realize how quick their intake charge is. From the front of the grille to the combustion chamber, air goes from outside the car to burning in a cylinder in a second. How much hotter does the air get? from 87.6* outside, to 87.8* at the throttle chamber?
joe603
Thanks Poyz! Yup, a lot of this is marketing from the CAI manufactures. I'm under no illusion that I'm getting a huge bump in HP with any intake...but I do know that it will give me the sound I'm looking for at WOT :naughty:
mich378
Car: 2009 G37 Sedan
Thank you all for the helpful advice. I ended up goin wit the Stillen gen 3 long tube for fathers day.
Poyzinous
great choice! But later on, you're gonna want to add the exhaust. It has a wonderful rumble to it. Plus, it'll help free up a little more power. What goes in, must come out.
gcirillo
Poyzinous wrote:good job joe. Another thing I tell people, is they don't realize how quick their intake charge is. From the front of the grille to the combustion chamber, air goes from outside the car to burning in a cylinder in a second. How much hotter does the air get? from 87.6* outside, to 87.8* at the throttle chamber?
But then why do all the car manufacturers snorkle the air from outside the engine compartment? They could save a lot of money and weight by having the intake sit under the hood.
I'm willing to be convinced either way, and neither of us has raw science to know what's right, which is why I default to what the car manufacturers do, since they have all the data and good cause to get it right.
Ironically, if I got the system, I'd be getting it for the induction sound! And that probably favors the short tubes.
joe603
Remember that OEM intake design is more concerned about noise then performance, especially in a luxury sports car.
audtatious
People confuse CAI with Ram-Air........Ram-Air is a myth.
joe603
lol, more like Ram Air is a throwback to the 70's. It helps with a carb engine...but even that is questionable. Just a marketing tactic by GM.
Poyzinous
ram air wasn't so much a myth as a misconception. it was fine for long run intakes on big bore engines. Otherwise, it was just a marketing ploy
