hehehehJacko3 wrote:zozoka:
No trouble here. I use 93. No thermal issues either
Thats what happens in a car without a knock sensor on each bank. If your car has a knock sensor it will ADD fuel and pull timing to make the motor run on less then perfect fuel. The problem is there is not infinite adjustment, when the motor has pulled as much timing and added as much fuel as it can and there is still knocking you won't know until something breaks.oldandslow wrote:Fuel octane requirements are determined by ignition timing for a given engine. Manufacturers choose octane requirements based on that given engines state of tune. Using a fuel with lower octane ratings than specified can be detrimental to that engine. Here's how it works. Lower octane fuels burn faster than higher octane fuels.Using too low of an octane fuel can cause predetonation.This is when the fuel is ignited too early because of it's faster burn.This happens when the piston is on it's compression stroke ,and still on it's way up into the combustion chamber.Ignition is supposed to happen just after this,when the piston is heading back down,which is it's power stroke.Since it is that explosion from the fuel ignition that forces the piston down in it's power stroke, imagine the forces against the piston,rod,crankshaft, & bearings, when this happens too early, as the piston is still heading up ,in it's compression stroke. Kinda like a head on collision.
I also buy the highest octane I can find. I have nearly $50K into my G, if I was worried about a $0.20 difference/gal between 87 and premium I would have bought a prius.gwoods wrote:I use the highest grade I can find and buy top tier (quicktrip, mobil or Chevron) gas only. Phoenix is 91 octane there are a couple place you can buy 100 octane
I run NOS or NX brand octane boost at the track although I'm not sure if it makes a difference.
Here we go againrn79870 wrote:This is going to be fun.
91 here, but we have hills, lots of hills.
Thanks for asking.How's your Mustang?SVTCOBRA wrote:Where have you been?I've you several times with no responses...
But it is such a satisfying thing when you do it right. Mess up, and its a different story...rn79870 wrote:Wow, telcoman. "Working on your own car" sure sounds like loads of fun ... Glad, nothing/no one got hurt.
My old jack also came with jack standsSVTCOBRA wrote:mustang is doing fine! Hasn't broken down all day! (also haven't driven it yet today )
I had a Sears brand floor jack poop out on me years ago and they did replace it with a Craftsman. I had to pay the difference cause the Craftsman came with a pair of jack stands.I had heard that the lifetime deal is just on hand tools.
Was at the local Sears recently to get a 5 drawer bottom unit tool cabinet to go under my other two. They had 4 in stock. ALL FOUR were damaged. I ended up getting the best of the 4 (slight crease on the side) for 10% off.Most of my tools are Craftsman & Kobalt
Glad you weren't hurt when the jack failed!! +100 for using stands!! (but have to take 1 back for 87 octane )
Thanks JackoJacko3 wrote:Telcoman:
Sorry to hear all these inconviniences you experienced. well, corporate america is bent on shafting its customers. I feel your pain. I am glad you did not go Jacko on the store manager or sales man. spending an extra $150 for a resolvable matter is really annoying. Have a popcorn on me
BTW, don't go Jacko on those talking about the fuel grade. Ignore it. Lets transfer the heat elsewhere .
