gs14racer wrote:
yes this happens, it happened on both my ka and sr. However the vh it apparently doesnt (or at least for me) happen, i got a gauge right at the rail and fuel pressure readings where spec.
Thank You!
The Walbro's high pressure output has nothing to do with the increased fuel pressure in the few cars that experience problems.
Pressure is a resistance to flow, and it is regulated by the fuel pressure regulator. The Walbro FLOWS more fuel at a higher volumetric flow rate than most OEM pumps. The OEM FPR's cannot allow the excess fuel to return to the tank at a high enough rat, causing increased pressure.
Observed on a rail mounted fuel pressure sender on dyno and datalogged on streets, most cars that have insufficient FPR flow are 4-cylinder cars, and the issue rears its ugly head at idle and part throttle cruise. The IDCs are so low and there are so few injectors that the amount of fuel getting out of the rail is less than the walbro is feeding in, and the fuel pressure spikes causing rich conditions at cruise and part throttle. At higher RPM and higher loads, the IDCs get high enough that the fuel pressure returns to normal and the tune is still accurate.
Interestingly enough, some of the cars that do experience 2-3psi greater rail pressure still achieve stoich conditions at idle and cruise after the LTFTs reestablish themselves, and since the ECU ignores fuel trims at WOT, the tune, again, is uneffected.
Like Jerry said, on the VH this appears to be a non-issue since there are 8 injectors and the FPR dumping the excess flow at idle, and the Walbro has no problem keeping up at WOT.
