what fans are you running?
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
What fans are you running....
part numbercfmpusher or puller?radiatorany other cooling upgrades?
I'm still over heating even with a new stock radiator and custom fan shroud.
Imissmyturbo
Car: Car's, Turbo's, sking
I am running no fans or shroud. I haven't overheated yet but I know if I get stuck in alot of traffic I will. I am planing on running 2 10-12" pushers on my car.
frosted flakes
i am running the stock a/c condensor fan (pusher) where it is rigged up so its turned on with the ignition....it doesnt overheat at all... its like a 10" dia fan....i have an aftermarket radiator with a thick core....its not one of those fancy aluminum koyos but a aftermarket replacement...i am running at 160F
maybe your thermostat is bad??
Nameless EJ6
Car: What the **** do you think.
Yesterday I picked up a VERY slim short clutch fan that I'm going to adapt to the stock fan wheel so I can have it run off the belt. Besides for that I'll be using pushers too.
PROJECTRB240SX
Its not the thermostat..... I just need to find twin shrouded pusher fans.
Wulfgang
Single 12" PermaCool high performance. Sounds like a tornado. I have no cat and N1 Dual, and the exhaust is hard to hear above the fan.... I need to put in on a thermo switch so it doesn't stay on all the time.
I think your 14" may be overkill. Remember that the tips of the fan blades push the most air. So even if your fan spec is 3000 CFM, most of that, say 2000 CFM is coming right off of the tips. It may not be going through the radiator at all.
I also mounted my fan near the passenger side edge of the radiator, since this will be where most of the water flows. The inlet and outlet are both on the passenger side, so that's where you need to plan on taking most of the heat out. If you only have a single fan, you are wasting it if you put it right in the middle of the radiator.
Does your heater put out hot air? Just checking because if you have blockage internally, no fan, no matter how efficient will help you.
PROJECTRB240SX
Yes, I run the defroster full-time and it blows extremely hot.....
I picked up twin 12" corvette pushers. They are hayden, I'm going to try these.
GTR Shop
Car: 180sx RB26 T78, Y31 Gloria VIP + HEAPS of GTRs!
GTR radiator with twin AC fans on the front.. never have any cooling probs.. the AC fans move HEAPS of cfm.Trick is having them mounted as clos as possible to the rad, and foam around edge beteen the rad and fan. so the air goes THOUGH the ad, not under the edge of the fan.
Nameless EJ6
Here's the fan I was speaking about above. I'll be fabbing it onto the stock fan location There should be enough room, this thing is pretty thin. it's not as bulky as the stock fan, but it will be nice knowing I have one running while the engine is running. I'll also be using pushers along with this.
http://www.we-todd-did-racing....DE%3D
EDIT: Copy any paste link if it doesn't work.
Joe
2 perma cool 12" pushers, one always on, other on a switch. havent had a problem
i think it was 1800CFM a piecestock 240 radiator.
Andrew85cm
Car: 89 240sx with RB20det
I will be running 2 10" slim fans that I got off ebay. The guy I got them from got the fans from summit and they push a good bit of air. They are pusher fans.~ANDREW~
PROJECTRB240SX
my vette fans work awesome..... I blew a turbo hose today!
Now I have to get a IC Kit.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Nameless EJ6 wrote:Yesterday I picked up a VERY slim short clutch fan that I'm going to adapt to the stock fan wheel so I can have it run off the belt. Besides for that I'll be using pushers too.
That is a neat idea! The only thing you might want to make sure of is that the fan you use can take 8000-9000rpm. Have you looked into one of those slim flexlites?
I ran a single a/c fan on my old red car and it worked well. I mght run a dual setup like that, but I really want to make this car as low on the "getto" meter as possible. Then again, if it works... it works.
Wulfgang
Weird thing...
I got into my car today with the windows up and cranked my RB20. The interior noise was extremely loud, like a very loud exhaust, even at idle. I have an N1 dual, which people have said is pretty quiet on the RB20.
After some checking, I pulled the relay for the single 12" PermaCool high performance fan I am running and the sound disappeared. As others have said, the N1 dual is VERY quiet and nice sounding. But the fan roars. I watched it for a while, and I think that the steel frame it comes with resonates at a low frequency, vibrating the whole car.
Anyone else have a fan this loud? I can't seem to get the car to warm all the way up with it, which is probably good, but it is much too loud.
Anyway, I plan to make a custom frame out of aluminum square tube to help stiffen things up. I hope this will cut the resonance out.
goofynick6
Car: 1995 S14.5 RB20DET
Just mount it with some rubber or foam insulators directly to the radiator and the rubber mounting of everything should take care of it. I had a 14" permacool with another 12" slimline running and it was fine.
Nick
Wulfgang
It is on foam insulators now. Anyone else have one of the high performance PermaCool 12" (not the regular PermaCool 12"). The high performance fans have a different, more open frame style. Maybe I'll call PermaCool about this and see what they suggest.
PROJECTRB240SX
MY PERMA-COOL PERFORMANCE FAN WAS LOUD AS HELL ALSO.... I HAD THE 14" FAN. ONE OF MY VETTE FANS BLOWS HARDER THAN THE 14" FAN I USED TO USE.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
I just installed my Koyo with Dual 12inch Imperial pusher fans (part 226112 from Autozone) I know autozone fans, but Autozone was open Sunday and the fans were $60 each.
NISMO_RB25
Here is another angle for you.
NISMO_RB25
With the AC condenser out of the way, the fans do not make contact with any part of the car other than the radiator. I was actually able to slide into place with the fans attached and not damage the radiator. (I do not recommend doing it that way, as you may not be so lucky).
I will take some pictures of it in the car this weekend.
cvc9216
how thick are those fans?
NISMO_RB25
Probably 2.5 to 3 inches. Thicker than the Flex-a-lite setup I had, but not much.
goofynick6
You actually have room for a radiator that thick? That's good to know :D
Nick
PROJECTRB240SX
I HAVE THAT KIND OF ROOM IN MY CAR.... I DON'T KNOW IF I WILL WHEN I INSTALL THE HYBRID KIT THOUGH.
NISMO_RB25
If you decide to keep the IC but not the piping, I will buy the piping from you.I may even buy the whole setup, if you don't want to the intercooler.
Wulfgang
The added thickness of the Koyo projects inward, towards the engine, doesn't it? So from the front of the radiator foward there should be no difference (I hope). You should be able to put anything in front of the Koyo that you could put in front of the stock radiator (such as fans, condenser, FMIC, or whatever you had before the Koyo).... at least that's what I thought.
NISMO_RB25
For the most part you are correct. The stock Radiator was not even with the end caps, so you actually had about a half an inch space on each side, that the koyo fills up . Your Condenser would still fit, but then you would not have a place to put fans.
I had dual slim 12" puller fans on my stock radiator that were between the end tanks so they were utilizing the half inch of space, but the Koyo, as you said projects into the engine bay twice as much as the stock radiator, so the puller fans would not fit.
I should have taken a side by side, the Koyo core is 3 times as thick as the stock radiator. I am ready for the Texas summer now baby!! Although me ditching the AC, may not seem like such a good idea in a few months.
PROJECTRB240SX
I'VE HAD NO A/C FOR THE PAST TWO YEARS IN AZ HEAT AND ITS NOT THAT BAD..... JUST ROLL THE WINDOWS DOWN AND DRIVE FASTER.
Wulfgang
Hmm.... heat must've cooked your brain if you think it's "not that bad" ;)
Imissmyturbo
You need AC in PA becuase the dam humidity! I like to take long trips down south and it's soo much nicer to have AC on those Hot Humid nights. 240's also suck with the windows down. There is soo much wind noise.
