RobDET »
https://forums.nicoclub.com/robdet-u7114.html
Sat Dec 27, 2003 1:09 pm
Here's what i have so far... not mutch really
*************************************yeah, I put it on a customer's car. they say that the turbo is a t28/t25 in reality it is just a regular t25. it does come with an adjustable actuator like the hks version. with the turbo, you have to reclock it and make sure the snap ring and all the bolts are tight, mine werent. the elbow fits ok, but it is a little close to the steering shaft on s13's. on an s14 it will clear perfect.cullen************************************Hey i havent recieved it yet, its not what i have on my car , this turbo is for a customer ive got a larger ts04 turbo on my sr20det but to tell you the truth the t25/t28 turbo is a bit small and not worth the upgrade, i know its cheap but the gains arent that much like you'd think especially if your t25 was running 0.7 bar already, if it wasnt get a "bleed valve" a fuel pressure regulator and hook it up, ill tell you how to if you want, the gains you will see are comparable to what you would see with the ssautochrome upgrade pretty much.
better to get a cheap manifold for a couple of hundread dollars and at least a t3/t4 turbo for the same price as the ssautochrome 25/28 as well as some piping and a nice intercooler kit, then you will see some gains that will be worth the money you spent.
Take care and tell me what you think***********************************************Hi Robert,
I haven't got the items at home yet, so I wouldn't know !What kinda car do you drive ? Cause I drive a pulsar GTIR (4wd 280 hp) And Ineed to change a few things before I can gett is to fit.***********************************************
