float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Oct 01, 2006 6:54 am
OK, 1st of all, I am running a Stage III 6-puck SPEC clutch and I don't have any slipping with it whatsoever. I've beat on it way harder than you have and with much more power, I promise.
Did you read the instructions at all? Did you follow the break in procedure? Did you re-adjust the clutch pedal? Did you have the flywheel surface stepped?
Mine did USED to slip on me. I always blamed the clutch. I replaced my clutch master in an attemt to fix it and it didn't work. Then I re-adjusted the clutch pedal. That fixed everything. The engagement point is still in a weird spot (not close to the floor like normal) but stepping the flywheel would resolve this. I haven't actually tried it or talked to spec about the stepping, but I plan on trying it later.
Don't blame the clutch/company for a bad product if it wasn't installed correctly.
Please don't take that the wrong way, but I personally badmouthed their clutch for a while, not realizing that the problem was installation error.
BBUUUUUTTTT to answer your question, the SR flywheel can SUPPOSEDLY be used, but the one guy (that I'm aware of) that has tried it, has had some issues. Knightrider, who works at JWT, is the guy who tried it. He used an SR Fidanza flywheel, a Z32/Maxima clutch, He had to grind down the inside of the bell housing in a few places, and lastly use a Hitachi, gear reduction starter from a CA18E(T). The key to making this work is the starter. It HAS to be the gear reduction starter, the one w/o a nose cone for the engagement gear. If you don't use that specific starter, the nose of the starter wlll rub on the pressure plate. Also, the biggest problem is that there is 1 or 2 teeth less on one of the flywheels. The longterm effect of this isn't know for sure.
You are more than welcome to use the above info to try the SR flywheel, but you are still basically a guinea pig. If you're going to be one, why not do it so that we have an application specific clutch instead?
And just to re-iderate:I am currently, and have been daily for about a year been using a JUN flywheel and a SPEC Stage III clutch w/o a problem. Drivin daily, and after I got it adjusted properly, it hasen't ever even THOUGHT of slipping.
