yngw13 wrote:
was it easy to repack the bearings?
I need to do this soon...what were the tools you used or required????
thanks
It's not really difficult. You remove and suspend the caliper, take the caliper bracket off, remove the rotor, pull the inner seal out, take the bearings out, clean and repack, then put everything back together.
There's a DIY here:
how-to-replace-brake-rotors-and-pads-fo ... 45492.html that shows how to get the rotors off. Once the rotor is off (around Step 7 in that DIY), you need to pull the inner seal out of the back of it to get to the inner bearing. I would recommend getting a seal puller, since it's not easy to get it out with a screw driver. I used the curved end of a hammer to pull it out, and it worked somewhat well. You'll need new inner seals, since they'll probably get damaged, although mine came out fine.
Also, the caliper bracket bolts might be a pain to undo. On the passenger side, I used my jack to push the breaker bar. That wouldn't work on the driver side since you have to pull the bar down, but it eventually gave in. I had to replace one of those bolts because it was pretty corroded, so it's probably a good idea to have a spare on hand. On my '96, they are M12x1.25 bolts, 40mm long with a 19mm head.
skiski329 wrote:^^^ same here on the repacked front bearings. I wish you took pic's, it would have been a useful diy.
Yeah, I was planning on taking pictures, but my hands were so greasy most of the time, I couldn't grab the camera. Sorry.
