I can be leaking into your booster and you will never see it till its filled completely. Then you will have to get a new booster.jt15833 wrote:I'll take a look at the wheels, and the master looks like the culprit but its not wet =/
thanks for the advice, i'll report back after i get a good lookover
^^ ditto. Had my front end jack up for two days.( don't know if it matters ) But came back and found a nice puddle of fluid on the ground and on the rim. Never noticed when the car was sitting flat tho.JDM240SXcoupe wrote:I had a problem like that. It was the caliper piston seal. How I notice, my rim was full of fluid n dirty while other rims where semi clean. Fix, replaced it.
