MAF? Connectors on it maybe?SUB ZERO CAR FANATIC wrote:I think i finally got my transmission issue resolved! still fine tunning, so far so good. After the engine warmed up and thermostat opened engine came up to temp stays just right, anyway i get back after driving around the blocka couple times pull in put it in park and the idles goes up and down, up and down, and its already warmed up, it doesnt do it until its warmed up.
The trans mission lines were backwards like i suspected, glenn...by the way if you read this post, the output line was on the passenger sidenot the driver-side of the transmission. And another thing, i didnt have toomuch transmission fluid it was still too low , i tried running it for 15 minutes orso and checking level is was way more than 1/2 shy, more like 2 1/2 shy.The reason i think it was boiling out was because the fluid was getting way too hot because it was so low , so i just went ahead and added it alland took a chance,after i added the 2 1/2 quarts it quit boiling over whenthe car was not running. Before i couldnt check it after it wasnt runningit was flowing over cause it was too hot,doesnt do it since i added the rest.now i got to figure out the brakes and the idle most importantly. i appreciate everybodys input and suggestions, thanksqship96 wrote: What was causing the issues with the transmission?
That's the valve I thought it was but I didn't want to say it and be wrong. When I posted, I was getting ready to close up the store and didn't have the time to search for it.maxnix wrote:IAC valve operating properly? Try 2.5 turns out from closed. Don't rely on engine tachometer for true reading.
I thought that was made clear in the first transmission thread you posted.SUB ZERO CAR FANATIC wrote:The trans mission lines were backwards like i suspected, glenn...by the way if you read this post, the output line was on the passenger sidenot the driver-side of the transmission.
Very informative. So tweaking the IAC isn't a good idea?Q45tech wrote:The ecu has 650 rpm stored as the desired idle speed [when the coolant temp is 174F] however it has the smarts to adjust the desired for stabilty.
The IAC is designed for 15% electronic addition air flow above the manual screw setting.
To maintain idle the ecu can adjust electronic duty cycle and change ignition advance as necessary. I'm sure the software has a feedback loop that decides that X amount of EXTRA Duty cycle should create Y amount of rpm change if not it adds or subtracts 1 degree of advance to find this spot where linearity exists. I has a long term and short term memory that it tries first then corrects,
This searching of just the right combination of duty cycle and advance to create 650 rpm goes on constantly.
When you slow down the ecu only knows you want idle when TPS voltage drops to 0.44 volts [foot off accelerator] then it starts trying what was in memory if it works OK then nothing else happens IF IT DOESN'T then it tries and tries to zero in on the correct combination.
AC on adds complexity because the drag from compressor and extra amps from alternator mean the norma IAC duty cycle is no longer 15% but around 35% so the primary memory is wrong and it has to use short term memory and still search a few tries to get it right.
Look up hysteresis:http://www.lassp.cornell.edu/s....html
Remember the system looks for a stable idle and as engine age the 650 rpm point may not be correct if 1 or more cylinders produces less power than the others. {Always do a power balance test when you spot weird idle to rule out plugs or dirty injectors}, if too much variation check each cylinder for compression variations.
The system was designed for a newish 100% functioning engine so you cannot fix idle rpm variations by tweaking IAC.
The rpms are the mathematical sum of 8 cylinders pushing and dragging the crankshaft around.
no it wasnt cause no one had a straight foward answer,including yourself!!!maxnix wrote:I thought that was made clear in the first transmission thread you posted.
Hope your plaentary gears aren't fried and clutches aren't scorched from lack of fluid!
So did i screw up by doing what MAXNIX said to do!!The plugs are bran new all the injectors were cleaned and soaked ininjector cleaner,blown through , all ohmed ok but i guess that doesnt meanthey couldnt be dirty though, i just wouldnt think so i soaked and cleaned them good! So what else should i check if plugs and injectors are ruled out! the car set up for about three years and had little less than 1/4 tankof gas left in it i added gas treatment and and heet then put about 4 or 5gallons of fuel in tank,could any of this affect idle? this is the first time engine has ran in 3 years is what im saying basically, so i wouldnt think anything would be dirty or plugged the engine was completely disassembled and cleaned,engine cleaned internally,fuel rails cleaned,injectors etc.!! what should i try next DENNIS?? THANKS FOR YOUR HELPQ45tech wrote:The problem with the IAC electronic duty cycle is 15% say 150 milliseconds of extra air per second is how much air actually flows. Certainly there is a difference between flows in a clean and dirty IAC.
SO 15% IAC duty cycle is relative, just an open time nothing more!
The ecu monitors MAF to gauge total inflow* and partitions this in its mind [memories] between under closed throttle, manual IAC bypass, and electronic duty cycle air.
* At idle the total air flow will be less than 10 grams [7-8 gm/sec] per second.
Don't be confuse that WOT redline flows ~~ 250 gm/sec not 80 as you would expect from above. Remember the closed throttle plate/ IAC seriously restricts flow by dropping plenum pressure. That's its purpose to choke the engine down so it cannot accelerate [increase idle rpm].
How idle is controlled:http://www.patentstorm.us/pate....html
I gave you a simple 30 second definitive way to check for yourself....if you chose not to take the initiative to confirm flow pattern and wait for other members to guess,whose fault is that? Spoon feeding stops in the highchairSUB ZERO CAR FANATIC wrote:no it wasnt cause no one had a straight foward answer,including yourself!!!
Who pulled your chain!! If i remember correctly i thanked you for your helpand your advice, all i was simply saying to brian was no one knew whichside was the output and that is a fact!!! i didnt say no one helped me or no one told me of ways to check and see which side was output.i try to be appreciative and respectful to everyone here especially myelders who have more experience than me, so why do you have to smart off and be a smart ***, you must be related to maxnix, ask a questionand instead of help or direction you get some immature smart *** response!!nico is a great place and i love it, but all it takes is a couple bad eggs to spoil a good thing!! i dont like to be disrespectful but its hard to respectsomeone who has no respect for others and always flying off at the mouth.if you dont have something helpful and posotive to say like Q45 tech andseveral others on here then keep your rude comments to your self!!!thanks for your wonderful inputqship96 wrote:
Duty cycle is a pretty good clue as to the condition of the IAC and the intake path in general.Q45tech wrote:The problem with the IAC electronic duty cycle is 15% say 150 milliseconds of extra air per second is how much air actually flows. Certainly there is a difference between flows in a clean and dirty IAC.
maxnix wrote:Duty cycle is a pretty good clue as to the condition of the IAC and the intake path in general.
brian........ do i crank car let it warm upshut it down and re-crank , then adjust 2 1/2 turns out? I also cleanedinsides of intake manifold very well. what else could effect idle?what about fuel leak? probably not hugh! i got a fuel leak now, its one ofthe short rubber lines at the back of engine under intake manifold, itsabout 3- 5 inches long from what i can tell and looks like it goes to thesmall little inline fuel filter or valve or whatever it is at thr back and beneathof manifold by rear of passengers side head. is there a special tool or phillips you use to get to those back little fuel lines or do you have to takewhole intake assembly off just to tighten one little fuel line?? thanksmaxnix wrote:Duty cycle is a pretty good clue as to the condition of the IAC and the intake path in general.
Hi Chris,T45 wrote:If your fuel lines are leaking then you probably have leaking vacuum lines causing your idle fluctuation. Possibly a disconnected line from your transmission venture? If you haven't done a hose rehab now is the time to do it and get it over with. My 92 had not one good hose under the plenum.
No, just do it at operating temperature.SUB ZERO CAR FANATIC wrote: brian........ do i crank car let it warm upshut it down and re-crank , then adjust 2 1/2 turns out?
im almost too embarrased to answer that question!! i just soaked them in injector cleaner and cleaned them real good and blew threw them with comp[ressed air. i replaced all the o rings upper and lowerpintle caps and screens and ohmed each one and put them back in.i guess i should send em off to Deatsch Works hugh! maybe ill just buy some new ones payday! i dont think thats my idle issue though,but maybe im wrong. i hear the fuel pump kick on when key is on sounds like its working fine,i need to get a gauge i guess and check fuel pressure.where do you check it at! thanks brianmaxnix wrote:No, just do it at operationing temperature.
Might be time to measeure your fuel pressure just to verify proper fuel pump operation. Did Deatsch flush your rials and injectors?
Condensation and separation are a real problem with fuel that old that has been just sitting. So you have never removed your fuel pump and inspected your tank? You have changed your fuel fiter and plan to do it again soon?SUB ZERO CAR FANATIC wrote:1.) i had some gas in tank that was in there for about 3 years when car sat, i wonder if that could effect anything if not treated!
2.) i put heet and a fuel stabilizer in the tank, i havent filled it.
Brian.......yes i did install new filter with all the other work done to the car, thanks for the tip on the HEET . so just install a tee after filter,and put a gauge on long end of tee, what type of gauge...anythingspecific?? stupid question but had to ask! thanksmaxnix wrote:Condensation and separation are a real problem with fuel that old that has been just sitting. So you have never removed your fuel pump and inspected your tank? You have changed your fuel fiter and plan to do it again soon?
Never Heet! Always ISO Heet! Difference between Methyl and Isopropyl Alcohol. You will need octane booster and a few cans of BG44K as well.
One needs to understand that hoses detiorate from the inside out, especially coolant and fuel and AC hoses. Exterior appearance does not assure interior integrity.
So how's the fuel pressure? Measure with a T fitting after the fuel filter.
