What can i delete off the intake?
TD or Not TD
Car: 1986 Corolla GTS
I am wondering what i can remove from my CA18DET intake manifold and still get it to run alright. i beleive there are 2 or 3 sensors controlling the idle. id like to eliminate some of the mess by the intake. ill most likely be removing the butterflys in the intake as well so i am not sure what i can remove there as well for the TVIS setup(i beleive thats what its called)
any help would be greatful .
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
uuum, it depends on what kind of engine management you are running. If it is the stock stuff, then you probably want to keep most of those things. When you remove the butterflies, you only get to pull the one actuator deal off.
edit: oh, wait, im dumb. go look at thewriteup on vacuum routing for the butterflies. you get to take ALL of that crap off. you only need one vacuum line to the fpr, one to the wastegate actuator, and i kept the ones to the charcoal canister dealie at the front by the air filter.
TD or Not TD
can you link me to the thread?
r34 gtr
gah!
zerothread/225309
i also removed all the cold start and idle junk, as well as the pcv crap. i seriously think i have saved 30lbs and i am in the process of removing even more stuff.
