What An fittings for top of valve cover?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Here's -8AN:
MATTs14
Car: Red 1995 Nissan 240sx
Ok so your valve covers are tapped to 1/2 NPT as well or what. God im confused. Do you just pull the fitting out or what
Darius
hahahaha for f#@$ sake man!
Take a large crescent wrench and screw driver and gradually twist and pull the fittings out of the valve covers. The holes left behind are luckily the perfect diameter for a 3/8" NPT tap so there is no drilling necessary. The PCV port on the side is also conveniently sized for a 1/2" NPT tap without drilling. Figure out your line routing and order fittings and lines accordingly. If there are anymore posts in this thread, Imma freak out!
Bluefire
I actually drillef mine out using a unibit and used a 1/2" tap.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
No longer need drilling and tapping. Just press these in.
RB20 and RB25 S1:
http://www.rawbrokerage.com/raw-brokera ... rb20-rb25/
RB26:
http://www.rawbrokerage.com/raw-brokera ... ings-rb26/
advan_s13
^^^^^^^ work like a charm. The choice I went with.
