Went to the track...and something broke :bash
importmyth01
Car: 1993 Nissan Silvia
So I took my S14 swapped S13 out to the local test and tune yesterday and was decently suprised.
Ran a 12.83 @ 113 with a 2.2 60ft
Mods:S14 Swap (Ball Bearing T28)15psiDown PipeExhaustWalbro 255IntercoolerZ32 MAF550cc InjectorsJ30 Rear EndEnthralpy ECUStill Untuned (Running in the 10.2-10.3 range on the wideband)Stage 3 Clutch (not verified but it snatches like one)195/60/15 Bridgestone Potenzas
Well on the 4th pass the car wheel hopps twice and then clunk!So heres the scoop...
-transmission will go in every gear not a problem no noises or harsh engagement-Clutch goes in and out with a harsh bit like usual no noises-DIRVESHAFT DOES NOT SPIN, BUT it is not hanging or any visual damage
Just thought I would take bets as to what the problem was? Any takers....Ive had numerous mechanics say clutch but it cant be (not ruling it out but the signs arent there) no noise or any symptoms.
Any ideas? I will be taking it apart tomorrow or by midweek to diagnose, my guess is maybe the input shaft is broken at the transmission?
KFL
Car: S14
To peep inputshaft..remove slave..pull rubber boot off carefully slides right off..shine light in and inspect. Should be able to tell easily if it snapped.
importmyth01
Input shaft for the drive shaft or on the transmission side? If drive shaft no biggy easy fix :whipes brow: if transmission....:bites nails:
importmyth01
ok anyone broken a clutch so bad that the car wont move? or should the driveshaft break first?
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I broke my ds that same way! (my car---> <---ME)
importmyth01
When you broke it did it hang down or did it break internally?
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
do you hear the transmission gears and stuff turning inside the trans when the clutch pedal is released?..if so then its not the input shaft...more than likley its the output shaft..if you dont hear anything then your input shaft has broke..sorry man
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Drop the transmission and look. Takes all of 30 minutes if you work slowly.
S14-NEO
i have also seen the clutch explode...which wouldnt be too hard to see...just yank out your pivot fork dust boost and take a look inside..it should be obvious..
supreamS14
the u-joint by the trans. broke right off the line! Then the front half of the DS flopped around in the trans tunnal messing it up to where a DS shop said they would half to retube it for $200 ! It was hanging so I knew what had happened. I dident want a half fixed old warn out DS so I payed the extra $115 for a New shaftmasters 1 piece alm. DS.
Emperor_Tha
S14-NEO wrote:i have also seen the clutch explode...which wouldnt be too hard to see...just yank out your pivot fork dust boost and take a look inside..it should be obvious..
Yeah I seen it too many times on evo. I swear first time I seen I thought a bird got caught up and blow n up. Thats would it looks like.
I've see a input shaft that broke on a gsx. The transmission was stuck and we had to buy trolly chair to push it.
importmyth01
Ok dust boot taken of and it looks as if someone dropped a bag of soot in there, but it just maybe dirty. I will be keeping an update tomorrow as the transmission will be coming down. doesnt look to hard to take down at all...if its the clutch I see everyone has had their fair share of problems with every brand?
Also in any gear theres no noise and the clutch pedal is hard like normal...i am more interested to see what broke then I am worried about the cra broken lol
S14-NEO
sounds like you blew your clutch disc apart man..
importmyth01
Yea sounds like it the problem it iguess i was hoping to hear noises or soemthing but to no avail.
Looks like if it is I will be ordering an Exedy ot ACT...I will post pictures and details as they come
supreamS14
+2 for exedy
importmyth01
well after about an hour of messing with the top bolts i said to heck with it and 45 minutes later i just pulled the whole swap out...ill have pics and a update tonight
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Can you post up the time slip.
DrifterProdigy85
you sure you didnt do something with the diff. wheel hop can be pretty violent for the differential.
importmyth01
dont know why the slip is needed but I am the right lane...
So I thought it was the Clutch, Drive Shaft or transmission...Turns out its ALL THREE..the output shaft on the transmission broke off into the drveshaft and its stripped out while doing so so the driveshaft is no good too the clutch looks like it has maybe 10k miles left on it. Also the pressure plate looks to be act and the disc is a oem exedy, so boo to the retard that put that together.
My next question is is it possible to swap out a output shaft on a sr transmission? and the SR and KA trannies are identical anyway right (I have a KA one lying around) <-havent searched yet
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
If the output shaft on the trans broke right under the shifter that is exactly what I did to mine. Rebuild using KA parts, is alot cheaper than finding a sr transmission. Thats what I did dint take long a few hours and ur done. Given that U have some experience with manual transmissions.
importmyth01
yea thats what i am going to do...by chance did you use new factory parts or did you just get a KA transmission and swap them over? Also isnt the KA transmission identical to the SR? Thanks for the help soldiers!
blacksrjdm
I used a used KA24DE trans. Bought it from a junkyard for 130 bucks. They are the same transmissions and was relatively easy to do.
supreamS14
Swap the SR bell housing to the Ka trans
importmyth01
Yea thats what i plan on doing...thanks guys ^^
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Wow thats a good time. If you could get some traction and get the 60' times down then you could be even faster yet. What state are you located in? Altitude is a killer where I am from.
importmyth01
Im in georgia...Update looks like i am going to have to get down and dirty for a cheap trans. Hoepfully by Saturday she will be up and running again.
And as for East coast guys looking to get a clutch cheap and quick check out http://www.CarolinaClutch.Com and ask for Tom Excellent service.
turbogeorgez
Car: 92 SILEIGHTY, 69 DATSUN 510
just thinking out loud you could have broken a spring of of the clutch and shougt it out into your bell housing. i only seen this once but it sounds the same a pop and clunk every once and a while
importmyth01
All the springs are there and I have done that a few times before on different cars but the clutch will still engage no matter what...unlike a broken output shaft the car wil not move at all
importmyth01
Ok so i put everything back together had a bit of a time with the transmission going on I kind of forced it by tightening the bolts to get it to mate properly. Loaded it up with fluids blead the clutch and went to start it and a loud loud screaching clanking noise came about. From searching around looks to be the position of the starter? Not sure but it sounds pretty bad going to remove the starter and inspect it all. I never removed the flywheen and I am reusinf the same starter.
importmyth01
Alright as retarded as is sounds its actually possible to "overtighten the starter" I loosened it and retightened to a little snug and VROOM VROOM!
Everything seems good but for some reason it seems as if the clutch isnt as hard as it was and the car seems to break up under boost...Ill keep an eye on things after around 500 or so miles
