No, but a big enough boost leak will outflow anything. If it feels like you are hitting a brick wall, that is fuel cut. Like the other guy said, ignition cutout would look more like \/\/\/\/\/\/\ on the graph. It wouldn't kill the ignition altogether.top_secret wrote:I don't think a Z32 mafs should max out that early...
c-rad wrote:This sounds like a MAF overrun issue and not spark related at all. Particularly because the increased airflow is causing the cutout sooner. I definitely wouldn't suspect the coils of being the problem since they can handle a lot more than 15psi... Did you go to a colder range of plugs or are you still using the 6's?
AmoebAssassin wrote:I agree...ignition blowout almost always looks like an erratic or peaked and valleyed HP/TQ curve, and never a clean drop.
Modified by JDMSIL80 at 8:53 PM 3/5/2006originalsin wrote:do you have an fpr?
LOL.originalsin wrote:yea i would think so, i mean a stand alone isent controling your ful pressure
the high pressure is +27.568 hp .... lolc-rad wrote:On that note, I dont know why everyone gets the "high pressure" version. It forces you to buy an adjustable FPR whereas the standard pressure one you don't need to.
c-rad wrote:
If you are running a Walbro 255 "high pressure", than the stock FPR is probably choking off flow pretty bad and raising the fuel pressure.
Modified by JDMSIL80 at 7:49 AM 3/6/2006originalsin wrote:not this is prolly the reason y your running tooo rich, its ok down low cuz your injectors arent firing as much and your motor can run off it, but once you got wot, and the revs/air flow climbs its opening the injectors faster and faster, and prolly dumping in fuel in liquid form, bogging the engine down, get a nismo fpr for an rb
No, because an overrun FPR will not give you linear flow. It would be damn near impossible to try compensating for that. Not to mention, it may not be the same flow everytime you are at a certain pressure. Just drop the $90-100 on an adjustable (+ $15 for a gauge) and be done with it.JDMSIL80 wrote:Not that I'm trying to cheap out in buying the FPR, but wouldn't tunning (leanning out) the fuel map of the Power FC can compensate the high fuel pressure problem of running too rich?? My A/F ratio at WOT is in the 10s, so I still have a lot of room for tunning. I just don't want to spend money on extra parts which are not needed.
Secondly, what is the ideal fuel pressure on the CA?
float_6969 wrote:Sorry to come in on this late, but I was running the stock FPR with the high pressure walbro and was definatly overruning it. My problem wasn't cutting out at high boost, but erratic AFR's. I'd make a run, compensate my low/high AFR's, and then the next run would be totally different. I got the NISMO FPR, and the erratic AFR's were solved.
In reference to your problem, I am going to have to agree with you that this may be a spark issue. The reason being, that although weak spark can show up as a rough curve, if they used smoothing on the dyno, you wouldn't see it. You've already got the coilpacks, try them first. If that doesn't solve the problem, get the FPR.
Also, unless you're exceeding 500hp, you're not overrruning the MAFS.
