Gas mileage isn't what I'd consider the end all to motor efficiency. I'd say power per cube is a far better example then mile per gallon. I don't consider mileage for the most part. My driving style doesn't allow for good mileage to be attained regardless of the vehicle. When I drive my wifes Dart, her average fuel consumption goes down quite a bitgwoods wrote:nearly WD.. the 5.0 NA version of my 5.0 supercharged Jag gets better MPG for some reason
<------Walking dead.XenonSE-R wrote:Dying Nissan fanboyism continues to die.
Right, but it doesn't make it not guzzle oil or suck at generally being a decent engine. THAT's the problem. The single worst and most unreliable powerplant Nissan has built in the last forty years is getting boosted. Meanwhile there's a perfectly reliable VQ35 sitting there not getting used.WDRacing wrote:Adding boost makes any engine more efficient. Just my .02
Right, but the Pathy and JX35 get VQ35s normally. Why are we downgrading to a QR and then adding boost? Why not just leave the VQ in there? Or at least boost an engine worth boosting. If Toyota, the king of hybridness, can put a 2GR V6 in a the hybrid Highlander, I think Nissan is okay pulling off a VQ in the hybrid pathy.WDRacing wrote:The Pathy and JX35 are way too heavy to have a NA 4 banger.
Oil consumption was only prevalent in the first generation QR. The 07~12 had very little problems with the motors. And that engine will be in the Altima tooMinisterofDOOM wrote:How do you improve on a crude unreliable, poorly balanced, oil-guzzling, fastener-ingesting, not-particularly-efficient four cylinder? ADD BOOST OF COURSE!!!! It certainly won't make it any less reliable!
The new Pathy and JX35 hybrids (nope, I'm not going to call it that) get supercharged 2.5 liters. I'm assuming they're QRs. No confirmation yet, but I can't think what else it'd be. 2.5 liter variants of the VQ have all been rear-drive versions so far (FWD VQ block is no longer anything like the rear drive block).
Specs are:
250hp
243 ft-lb
26mpg combined.
This just seems silly to me. Add boost to a crappy engine to equal a good engine? How is this any better than the VQ? Its fuel economy is actually quite decent. In my dad's VQ35 Maxima, I've never had any trouble averaging mid 20s even with aggressive driving. And the VQ is more powerful with an even better torque curve. Sure, the Altima gets better EPA ratings than Camry or Accord, but that's because both of those cars weigh seventeen million tons but continue to use torqueless wonders in their base models.
I could see an MR20DDT or something like that. But a QR25DET? WTF Nissan? Tell me there's something else going on here!
Oh, also: Highlander hybrids get 2GRs. Why does Nissan's hybrid get a powerplant nerf?
That's wise. But in all fairness, the oil guzzling problem with the 2.5L Alti motor was not the motor istself, but the cheapie catalytic converter, and Nissan's delayed response to it. They did eventually address the problem (not well), but once they changed cats, the engine was reliable. Of course, after Nissan fixed that converter problem, they switched over to CVT, which created a whole new problem, which is why I'd avoid buying a used 4 cyl Altima now.Jesda wrote:When I see an Altima 2.5 roll across the line at the auction I'm always tempted to buy one because they look decent, drive okay, and go for dirt cheap.
But I could never do that to a retail customer. My reputation is on the line.
I believe that would actually be a QR25DER, right?MinisterofDOOM wrote:I could see an MR20DDT or something like that. But a QR25DET? WTF Nissan? Tell me there's something else going on here!
Oh, yeah. Yep, 4 for supercharger.Dattebayo wrote:I believe that would actually be a QR25DER, right?MinisterofDOOM wrote:I could see an MR20DDT or something like that. But a QR25DET? WTF Nissan? Tell me there's something else going on here!
I'd like to see your data.alphapig wrote:reliable engine
Anecdotal data. Low in value I'm sure, but higher than 20y.o. misconceptions.PapaSmurf2k3 wrote:I'd like to see your data.alphapig wrote:reliable engine
Bubba1 wrote:But in all fairness, the oil guzzling problem with the 2.5L Alti motor was not the motor istself, but the cheapie cat
THAT is the key. The QR is an average engine with FREQUENT problems. Your average Altima or SE-R buyer in 2001 was the victim. Not tuners and gearheads. Lots of average people doing average things with the engine had issues, despite not asking much of it.PapaSmurf2k3 wrote:The KA's, CA's, and SR problems usually didn't just happen to every day people
