Weird sound in front suspension
aleph1
Car: 1990 240SX hatch MODS: class.
Are positive you installed the bushing correctly, you need to grease them and tighten the bolt when the car is on the ground.
Boricua
oops!
well i don´t grease them!!!but i tighten the bolt when the car is on the ground, that´s all said in the manual, and there no way that i can put the bolt if the caqr isn´t on the ground...
if this grease could wait until next weekend i´ll do it...i´m tired of this problem... :)
thanks...
Boricua
FINALLY!!!!!!!!!THE SOUND IS GONE!!!
it was only that 2 or 3 nuts need to be thigten...on the tension rod... the part that holds the tension rod (plate?)... ;)
not springs, not tie rodends, ... :)just need a good mechanic... lol:ylsuper
