Yea I'm hoping the timing is just off. The CAS (cam angle sensor right?) is the one on the further most cam (exhaust cam) on the driver's side right? The little slots where the bolts mount to (long slots for adjustment) are all the way to one side, which to me doesnt look right. I know on hondas, you turn the distributor to fine tune to help idle as well as detonation/retard. If the CAS does the same, then mine is way out of spec being all the way adjusted one way.H1tman wrote:The belt might have skipped a tooth, probably when he replaced the pulley. You'll know if the CAS is maxed out.
The driver side cylinders have very low compression, maybe your battery drained a bit. Almost seems like your did the passenger side cylinders first and the moved to the drivers side. If you did you should it again but start with the drivers side. If not then its no bueno.
Yes that is the CAS. Like H1tman said the timing belt itself is probably off a tooth or so since the CAS is maxed out to one side (to try and make up for the difference).Yea I'm hoping the timing is just off. The CAS (cam angle sensor right?) is the one on the further most cam (exhaust cam) on the driver's side right? The little slots where the bolts mount to (long slots for adjustment) are all the way to one side, which to me doesnt look right. I know on hondas, you turn the distributor to fine tune to help idle as well as detonation/retard. If the CAS does the same, then mine is way out of spec being all the way adjusted one way.
Most engine cylinders wear fairly equally, so having one side that far off from the other side sounds like a different issue. It's either the head gasket itself, the head bolts no being torqued down enough, or the cylinder head on the driver side is warped and not sealing correctly. Could also be an issue with valves not closing, but I doubt it since all 3 cylinders have low compression (110 is too low also, not just the 90 and 98).As for the compression test, I actually did the driver's side first. I also had jumper cables hooked up to my other car while it was running to make sure the battery didn't get low. The engine was warm, and it was a dry test. The car backfires some if I let it sit at idle and then tap the gas real quick. It will backfire just before the rpm jumps. If I let off and then let it idle and then tap the gas quickly again, it will do just the same.
It overheats when driven because the engine gets hotter under load. You can burp the coolant system, but it's probably not the full issue. If one whole side has low compression, AND the car overheats, AND has no power, it's an issue with the head gasket and/or cylinder head itself. This would also cause the low idle and the car shaking (mismatched power output on either side of the engine causing vibration). You might need to have the head taken off and checked.Also I noticed today, the car only overheats if it's driven. If I just let it sit at idle, it seems to not climb anymore, but slowly starts going down. Once it's driven, the temp will start to rise again. I didnt get to burp the radiator hoses today.
Ok, I'm about to head out to go check the timing. Just so damn hot outside it's gonna suck taking off radiator and fan and all the parts to check the timing, but it's gotta be done.t.mcginley.jr wrote:Yes that is the CAS. Like H1tman said the timing belt itself is probably off a tooth or so since the CAS is maxed out to one side (to try and make up for the difference).
Yea I figured the headgasket was going to be an issue regardless.t.mcginley.jr wrote:Most engine cylinders wear fairly equally, so having one side that far off from the other side sounds like a different issue. It's either the head gasket itself, the head bolts no being torqued down enough, or the cylinder head on the driver side is warped and not sealing correctly. Could also be an issue with valves not closing, but I doubt it since all 3 cylinders have low compression (110 is too low also, not just the 90 and 98).
As soon as I figure out whether the timing is right or not I'm gonna pull the valve cover and check the bolt torque on that head.t.mcginley.jr wrote:It overheats when driven because the engine gets hotter under load. You can burp the coolant system, but it's probably not the full issue. If one whole side has low compression, AND the car overheats, AND has no power, it's an issue with the head gasket and/or cylinder head itself. This would also cause the low idle and the car shaking (mismatched power output on either side of the engine causing vibration). You might need to have the head taken off and checked.
I pulled out the coolant pipes (both hard pipes) and only got about a drip total from both. Although there was a little seeping from behind the thermostat, which I left in place so I wouldn't have a big mess. It dripped for a few minutes and then stopped, still haven't pulled the water pump yet, as I still have the crank pulley on (prolly get it off tomorrow).H1tman wrote:Pull out the water pump and coolant pipes and you'll find out where the rest of the coolant is. Theres a drain plug for the block, try that.
Yea. I've heard the rear marks aren't very accurate. Tomorrow I will be pulling the crank pulley (hopefully it's been removed before so it's not killer to take off) at that point I'm gonna turn the crank until I get as close as possible to the original marks on the timing belt and cam gear marks. Then I'll be able to see how bad the timing is actually off. I'll snap some pics before I change the timing belt so I can post up.H1tman wrote:Yeah it's off. They will never line up EXACTLY but they should be really close. If you change the belt yourself make sure you line up with the cam sprockets with the marks on the belt and not on the rear timing covers.
I'm gonna reset the timing and see if it will fire up and run and run good for a few seconds and then I'm gonna do a compression test again to see if the numbers were out of spec due to the timing. It doesn't smoke at all, nothing whatsoever.t.mcginley.jr wrote:You should still pull the valve covers and check the head bolt torque. If the torque is fine then it's probably a bad head gasket that's causing the low compression on the driver's side. Does the exhaust smoke at all?
Which cogs are you talking about? I was just gonna put the crank to TDC and pull the belt and reset everything and replace the belt...nissanfreak12 wrote:Before you pull anything from the timing, count the cogs. Yes, the marks do not accurately line up, as stated earlier, just for reference. It very well could be on, but will not know until the cogs are counted. This is the only way to accurately do the timing belt check.
Ahh gotcha. Just did the the upper cogs. Passenger side head (intake cam to exhaust cam) 23 cogs. From intake cam to intake cam, 45 cogs. From intake cam to exhaust cam on drivers side, 24 cogs. Just loosened the crank pulley bolt, which came off with little effort, and I mean little, like 20ft lbs... So i'll count those which there are supposed to be 59. The cogs aren't a sure fire way since I never set the motor to TDC and most accurate way to do that would be the crank marks.. Which I am about to do. I'll post in a min.H1tman wrote:Read the FSM, it's on here for free or google it. Cogs are the teeth on the belt. There should be a certain amount of cogs on the belt between each mark on the cam sprockets.
Lol no that's why I stated that I would be pulling the crank pulley to verify TDC...H1tman wrote:Wait..what? You never set it to TDC?
After pulling the pulley and setting to TDC via the mark on the crank, the passenger side was the only cam that was off. (passenger exhaust) and it was only off a tooth. I haven't compression tested again yet, but the car runs better, but still like s*** and powerless, nonetheless.nissanfreak12 wrote:Yes, when you count the cogs, go mark to mark on each pulley. Look up the FSM, follow it to the letter when it comes to the timing belt. If this is set wrong will cause a ton of issues, running bad, overheating, poor power. The crank pulley will have a dot on it and a notch taken out of the oil pump. Those are the only ones that match up exactly, this is also TDC.
If you counted correctly, the passenger side is off, which I am sure you have already figured out. I would reset the timing and redo the compression test again, may not have to take apart the cams and test the bolts for tightness.
I was thinking the same thing. It's just more of a reassurance thing that nissan did I think to help make sure everything is spot on.t.mcginley.jr wrote:Not trying to threadjack I swear! But I have a question..
I'll be doing my timing belt soon and I know the procedure, but about counting the cogs... I don't know if it's just my brain not working today or what. I understand that if the timing belt is installed correctly, all lines on the belt will line up perfectly with the marks on the cam sprockets and crank gear. But say if the belt was installed one cog off, with the lines being one cog to the right or left on all the gears. Wouldn't there still be the same amount of cogs between gear marks? I feel like I'm missing something...
Feel free to fill me in!
Yea figured the exhaust wouldn't cause much of an issue.t.mcginley.jr wrote:No the one muffler wouldn't make any difference to the power of the car.
Yes cats can get clogged and cause problems. The stock precats are just an emissions precaution... like pretreating the exhaust before it even hits the main cats. On their own they are a big power restrictor, but they shouldn't cause issues such as no power. Most people replace them with aftermarket downpipes, which are just straight pipes from the turbo outlet to the midpipes (or test pipes if you have them).
Now that the timing is back on right, you should do the compression test and see what the results are. If still low on the driver side its a head gasket and/or cylinder head itself issue. let us know what happens
