joe603 wrote:...this is why I won't clean my TB or MAF.
Nor do I, I only clean a throttle plate by spraying it I never touch them.
joe603 wrote:Reset the ECU. Try the easy way first (unhook the NEG battery terminal and pump the brakes a few times), then the other more complicated method if the problem persists.
Nice, old school trick. I have seen these procedures but I find them infuriating and they require specific actions. It's like programming remote. That drives me nuts, lol I am spoiled though.
BrandAidDesignG35 wrote:vacuum leaks? did you leave a film on the MAF?
Probably not since the from the description that John provided. PS very cool avatar.
-John I really think that depending on how exactly you did this you might have damaged the throttle motor. Please tell me the key was off when you did this and you didn't force the plate open. It really does not take much to damage the motor. IDK why it is it just doesn't like that. sry. If you cannot get the idle to drop to 750ish on its own and your CEL keeps coming back you might have a problem. That has happened many times that I have seen. I remember in 03 when the electric motors became more popular we were recommending induction cleaning at 30k intervals (as per the product manufacturers "testing" results) the down side to this was the fact that we could never get them to relearn idle or if they would they CEL would come on later, now this did not happen all the time but at a frequency rate that makes me not sell them under normal circumstances and I primarily use them on for very dirty older cars. Most Gs do not really need them if they are properly maintained.
Did you get an ISC system function or a throttle motor circuit/TPS sensor DTC?
If you let me know what code you got I can point you in a better direction.
