Hmmm...so it may very well be the cold temps here...unfortunately I won't be able to confirm till its around may-juneMark Booth wrote:I'm in sunny Southern California and I open/close the hatch on my EX35 at least 4-5 times throughout the day. As early as 6:00am to as late as 10:00pm. As best I can tell, the struts are working just as they did the day I took delivery of the car.
Mark
My previous FX had the same problem and it was really bad in the winter. The dealer fixed it under warranty and it cured the problem.EX-lover wrote:Same here in Toronto, never happened to my old Acura RSX hatch. I wonder if FX have the same problem in past winters.
It was Agincourt Infiniti at the time which I believe became Markham Infiniti.EX-lover wrote:Thanks KJ911TT. I will mention it to the dealer at my next oil change. Just my curiosity, did you buy (and got it fix) from Markham Infiniti?
Leave it a while in a somewhat warm garage, then give it a try.EX35_bernard wrote:
They should, my struts started to act strange since late last night temp below 70F.chichi wrote:Is this issue in any TSB's?
Modified by chichi at 7:43 PM 12/4/2008
That sucks. I just learned to ignore mine or lift it up more. I think they undersized the struts to cut some costs. The hatch is actually very light I think its aluminum like the hood. Hopefully when the warmer weather shows up they will improve.chichi wrote:Recently noticed the same thing and hit my head. Dealer says the struts are back ordered but will replace under warranty. Also had the fuel pump replaced under warranty. Don't think the issue with the hatch is weather related.
*UPDATE*
2 weeks after getting the fuel pump replaced my vehicle still reeks of gas, less so now, but nevertheless still present. Dealership claims " no gas spilled "but note that the fuel pump is under the drivers seat and gas did spill when it was replaced. My front and rear drivers side rugs stink of gas. Service manager claims he can't smell it, ya, right. I guess I'll throw out my rugs and buy new ones hoping the issue is under the seat.
Secondly, I had the hatch struts replaced under warranty yesterday and the effect was worse than the originals. Bear in mind 6 Mos. ago the hatch lifted effortlessly, all the way up, slowly. First the service manger claimed to not see a difference (despite hiding his left hand and lifting while opening the hatch with his right ) I walked over to my loaner EX and it worked perfect and he still said he didn't see a difference. I said, ya, right, you wouldn't. He offered to PUT BACK MY OLD ONES or order another set. Obviously I asked for another set BUT what can I expect with them?
All in all, my EX has lost a bit of it's luster and I'm finding that Infinity Service managers are just like all the rest- hold the company line by being less than truthful/honest.
It just pisses me off...
Modified by chichi at 12:54 PM 12/3/2008
I guess Infiniti is still trying to force the strut contractor to work on the updated ones, they will start posting TSBs once they have stronger struts, until then they will be wasting money on putting ones which will go bad soon or later.EX-lover wrote:My dealer is ordering parts to fix the weak hatch struts, however the technician said the problem will probably come back in 6 months. WTF??? That is not really fixing the problem!!!!
Hi EX-lover,EX-lover wrote:My dealer is ordering parts to fix the weak hatch struts, however the technician said the problem will probably come back in 6 months. WTF??? That is not really fixing the problem!!!!
im 5'9" and experienced life threatening head banging. I opened it fully with my hands and it slowly came down. OUCH!dividedhighw wrote:Thanks for keeping the discussion going, guys - any further info on this (especially an actual TSB number) would be very much appreciated!
FYI, I'm just shy of 5'10" and have banged my head a couple of times (when hurriedly loading something into the back) ... clearly not life threatening, but annoying, just the same!
TIA!David
Well, I couldn't disagree more.EXceptional wrote:Instead of all of us crying about how crappy our Struts are, we could wonder why the Infiniti just has 2 Gas Struts and the Nissan has a Power Hatch (which I know still uses Gas Struts) ?
Anyone who figures things should work at-40*C like they did at +40*C should maybe move to California.
That's great that you have such a magnanimous and forgiving nature. Too bad it wasn't just a little more developed - enough to stop you from disrespecting other viewpoints by characterizing it as "crying".EXceptional wrote:I too noticed that my Struts didn't lift the hatch all the way, but in a few Months, it'll all be over... and Summer will be here again.
I'm willing to over look this little problem, because I haven't had a Leaky Sunroof, Crappy Fuel-Mileage, Tic-Tac Noise, Noisy Fuel-Pump, Broken Telescoping-Tilt-Wheel, etc... (except for a busted LDW Camera, which doesn't bother me either, cause I never use it).
Indeed - as requested.EXceptional wrote:Let the Flak begin.
Good for you to be happy. When I saw my friend opened his 4 yr old, 28K Subaru hatch with one finger at 20 below, it is painful for me, i spend 20K more on my car, i expect a little more.EXceptional wrote:Instead of all of us crying about how crappy our Struts are, we could wonder why the Infiniti just has 2 Gas Struts and the Nissan has a Power Hatch (which I know still uses Gas Struts) ?
Let the Flak begin.
Good point - I have an '05 Subaru that does EXACTLY that!!EX-lover wrote:I saw my friend open his 4 yr old, 28K Subaru hatch with one finger at 20 below
I can open my Hatch with one Finger as well.EX-lover wrote:When I saw my friend opened his 4 yr old, 28K Subaru hatch with one finger at 20 below...
