Truth.Bubs daddy wrote:Slower, steady speeds will yield better mileage. Feather the accelerator pedal when starting from stop. Different gasoline formulas required by your state or area affect mileage. Going 80 mph will definitely use more gas than going 65. Going 55 will get better mileage than 65.
Not necessarily true. While going higher speeds to increase fuel consumption, each car has a "sweet spot" where the increase in speed is greater than the increase in consumption. Saying every car gets the best gas mileage at 55 is like saying that every tree is the same, or that a burger is the same at any place you get it. It's simply not true.Bubs daddy wrote:Slower, steady speeds will yield better mileage. Feather the accelerator pedal when starting from stop. Different gasoline formulas required by your state or area affect mileage. Going 80 mph will definitely use more gas than going 65. Going 55 will get better mileage than 65.
That blows my mind too - using a higher octane than what the engine calls for doesn't do anything to help with efficency. Not saying you're not getting those gains, but theoretically it doesn't do anything.DejaWiz wrote:Driving about 90% city:- My V gets about 23mpg average with the ethanol blend- When I use the 87 regular, my V will get 24-25mpg average.- Using 91 premium, my V will average 26mpg.
Exactly my thoughts on it, as well. I switched back and forth between 87 and 91, and the mpg were consistently observed to be around 24.5 and 26, respectively.marlin29311 wrote:That blows my mind too - using a higher octane than what the engine calls for doesn't do anything to help with efficency. Not saying you're not getting those gains, but theoretically it doesn't do anything.
You mean 20"s not 20's right?superskunk wrote:24 in the city? i recently got 26 highway.... with my 20's on... yeah i know it sucks... but whatever... i need to put my 15's back on so i can get better mileage...
...which is in essence saying that every car does it's best at 55. Does the car get better gas mileage at 45? Then 35?? Hell, I should just stop driving because that's my best gas mileage!Bubs daddy wrote:
Bulltucky.
I didn't say every car gets best mileage at 55 mph. I stated you'll get better mileage going 55 than 65.
Sweet spot? On what vehicle? Unless you're in neutral going downhill, the fact is, going 55 mph will give you better mileage than going 65.
Going 65 mph takes more fuel. Going 55 mph takes less fuel.
Your analogy doesn't make sense. Comparing burgers and trees is ludicrous. A Ford F150 will get better mileage going 55 than 65. As will a Honda Accord, a Chevrolet Corvette and a Toyota Corolla.
At a steady, constant speed, going 55 mph will get better mileage than going 65 mph. Going 65 mph will get better mileage than going 75 mph.
YOU need to read what I'm talking about - I'm glad you know the gas mileage I'm getting without driving my car buddy. Constant speed going 70 mph i get around 28.6 mpg. Constant speed at 55 gets me about 27.1 mpg.Bubs daddy wrote:Who stated anything about the EPA? I didn't.
You need to read what I wrote. Going 45 mph will get better mileage than going 55 but that's not what I was discussing.
The original poster's question regarded highway speeds so I was stating as such. You need to read what I wrote. I never stated in the above posts that mileage at 55 was better than 45 or the best mileage is solely at 55 mph.
It's simple. At a steady, constant speed, your engine is at a higher RPM and sucking in more air at 65 than 55, thus so it takes more fuel.
And because it's going 18% faster doesn't mean it burns 18% more fuel. I never said that. I said it uses MORE fuel, not an equal percentage related to the speed. Perhaps it uses 5% or 7% or 3% more fuel.
And your Altima does not use less fuel at 70 than 55. You're deluding yourself. Your car's engine is running faster and taking in more air so it needs more fuel. So unless you're comparing going 70 mph at 9000 feet above sea level and going 55 mph at 1000 feet, your Nissan gets better mileage at 55 than 70.
It will also get better mileage at 45 than 55. It will, however, get to a point of insignificant fuel savings at much lower speeds. Again, constant, steady speeds at the same elevation.
Modified by Bubs daddy at 1:15 AM 10/19/2008
In this statement, you say that I am using more fuel at 70 than at 55, to which I agree - I do use more fuel. However, you then elude to the fact that I get better mileage at 55, which is a completely different arguement, which is wrong - I get better overall mpg's going 70 versus 55.Bubs daddy wrote:And your Altima does not use less fuel at 70 than 55. You're deluding yourself. Your car's engine is running faster and taking in more air so it needs more fuel. So unless you're comparing going 70 mph at 9000 feet above sea level and going 55 mph at 1000 feet, your Nissan gets better mileage at 55 than 70.
You have to be so close to the car in front of you to realize any true gains from drafting - this one is debateable.raventare wrote:
The best way to save gas is "draft" the car in front of you but watch your temperature gauge if you are going fast and please NO texting or talking on the phone...YMMV
Thank you.marleyfan wrote:I recently saw a consumer news segment that tested going 90kmh (56 mph) vs 110 kmh (68 mph). I think it was in a toyota but I can't recall. They used an onboard computer similar to the scanguage. They drove the same section of highway repeatedly under the same conditions and didn't start measuring until they had reached the target speed. They found that going 56mph used an amazing 30% more fuel than going 68 mhp. I realize that not all cars will get the same results but it was certainly a wakeup call for me. Perhaps someone with an unmodified Versa and a Scanguage could try it and let us know the results and put this argument to rest.
Hmmm....first time I've quoted myself. Anyway...I inadvertently reversed the numbers. The finding was that going the faster speed used 30 percent more fuel.marleyfan wrote:I recently saw a consumer news segment that tested going 90kmh (56 mph) vs 110 kmh (68 mph). I think it was in a toyota but I can't recall. They used an onboard computer similar to the scanguage. They drove the same section of highway repeatedly under the same conditions and didn't start measuring until they had reached the target speed. They found that going 56mph used an amazing 30% more fuel than going 68 mhp. I realize that not all cars will get the same results but it was certainly a wakeup call for me. Perhaps someone with an unmodified Versa and a Scanguage could try it and let us know the results and put this argument to rest.
Just wondering how you got these figures. Cuz they contradict everything I have read on this subject. Did you do this under similar conditions and measure using a scanguage or similar obdII computer?marlin29311 wrote:
I get it from the computer readout built into the altima based on the same 40 mile patch of I-95 between NJ and philly. I go to philly a lot (graduated from school there) and I tested this out. No A/C either times, windows closed, fair temperatures, minimal traffic, if any. Almost constant speed (impossible to keep a constant speed with hills and such). I'd take pictures of the computer, but I don't take pictures while driving.marleyfan wrote:
I said that my car uses more gas - however, the increase in speed outweights the increased consumption in fuel, therefore giving me slightly better gas mileage. Once I start hitting 75 or so, it tops off and my mileage starts to go down.Bubs daddy wrote:You admitted your car uses more gas going faster. That's what you said. Then how can your car get better mileage going 70 mph than 55? You just contradicted yourself.
I'm my own engineer - I do my own work, I read all the service manuals, and my Dad works for a company that helps build components for Nissan. I have a fairly high working knowledge of my car, and could easily attain my ASE certification if i needed to - I'd rather work in insurance though; pays much better.Bubs daddy wrote:Ask a Nissan engineer if your Altima gets better mileage at 55 mph or 70 mph.
Because they'll prove that you're wrong. Sure, some cars might fit this bill, but after all of the research that the guys over there do, they can also show that going higher speeds in certian instances gets you better miles per gallon.Bubs daddy wrote:And why would I need to go into another area of the forum to state what has been known for years? There are people that belong to the flat earth society as well. Doesn't make the right. What do you think was one of the main reasons the federal government proposed a national speed limit of 55 mph in the 70's? To save fuel.
