I have a aftermarket intake manifold and am ditching the stock oil cooler too. Here is my question for now.
In this picture, are these where the water return lines for the turbo (hard steel lines that have the banjo bolt) will go? i am redoing all this in braided line and getting rid of all this dumb stuff on here. the oem lines where all kinked and broken and some where missing when i got the motor so im trying to double check.
Pics here
This appears to be in a "loop" if you will. can i cap off the rear most line (or the front one) or does it have to remain in a loop with the turbo returns?
About the AAC/IAC, i am running a throttle body so wouldn't i have to weld a bung on my charge pipe before the throttle body and hook up the AAC to that for it to work correctly, right? On my setup, the AAC bolts directly to the intake manifold. so i was thinking instead of welding a bung on my charge pipe i would just use a small air filter on it.
For the Air regulator i was thinking of welding a -10an bung on the bottom of the manifold and hook up the one side to that and then run another filter on the other side of that...
Pic Here...
anyone see any problems with that?
thanks guys,
Lee
