We have a new addition to our family...My youngest son Evan purchased his first car. A 96 Civic hatch. Already had v-tec-swap-hack-up-with "most hardware missing" job.
It's a piece of work...but we got the air conditioning going, fixed the alternator, replaced the suspension and the stereo, removed the exhaust and installed header. We are waiting for cat-back exhaust and Evan is trying to figure out the wheels. Lots of fun and getting some quality time with him.
Anyway...that and Cameron's car have kept me away from Betzy. I did get a few things done today.
I am removing the original oil filter housing/water heat exchanger that comes stock with the engine. This is how it came.
I removed everything and purchased an adapter from Rickey at Raw Brokerage. Now you could just screw a filter to the block. It's a 3/4 X 16 thread (same as stock Nissan and Ford, Chrysler, Dodge filter).
But... I am going to use a remote filter for ease of filter change and my remote has a valve that will direct the oil to a cooler when it gets hot.
Here is the block adapter.
Here is the remote and the little bracket I made up. It bolts to the frame.
Filter access is now down here behind the front cross member.
The two bolts securing the bracket go through the frame. I also made up a little plate that sits on top of the frame to help protect it.
I made the hoses to connect the adapters...
And then the hoses to the cooler...
I don't have a cooler yet. The hose loops up around, in front of the FMIC for now. I'll figure something out...
Time for a beer...cheers *clink* happy 4th.
Gord
