Watch Movies on Navigation Screen while JX35 is moving!
Discussion forum for the Infiniti JX35 / Infiniti QX60 - This 7-seat premium crossover dominates the class.
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
Update the iOS on your phone, that is the problem!!!!
SBCKNOX
Car: 2013 Pathfinder Platinum
Currently have 6.0.1. 6.0.2 is suppose to have wifi fixes but also has some wifi power bugs. Is 6.0.2 suppose to fix the bluetooth?
Timmbo
Yes, many people with the JX had the same issue with the iPhone 5, once they fully updated with the recent iOS update, all was perfect!
amckean
Car: Infinity G37
Hello all...new to the forum. Do any of you know if the above will work on a 2013 G37? Obviously I want to bypass the in-motion restraints on the DVD and Navi system. Thanks in advance. I'll be ecstatic if so. While I'm at it, anyone know a workaround to play videos from iphone and/or just mirror the iphone on the G37 navi screen??
Aaron
SBCKNOX
Updated to 6.0.2 but still wont pass incoming calls to system. :0(
All other aspects work fine. Can even route call to MY-CAR after answering phone via iphone or speaker.
Jack
mrbizzy
Hey Timmbo,
Would you by any chance have a copy for the FSM for the 2013 Pathy? I'm still trying to figure the AV pin layout and the dealer wants $230 for the FSM.
Thanks.
Timmbo
You can download a 24 hour subscription for $19.99 here:
https://www.nissan-techinfo.com/search_results.aspx
Save or print what you need and you are all set!
Timmbo
mrbizzy wrote:Hey Timmbo,
Thanks.
You sure you were not looking at the wrong plug harness? There are several of them, I would just be really shocked if they were different between the JX and the Pathy, but I guess anything is possible.
mrbizzy
Thanks for the quick reply Timmbo. I'm pretty sure I looked at the right plug. I'll look at it again the is weekend just to make sure. I went to the website you suggested and the FSM was not available for the 2013 Pathy.
Timmbo
mrbizzy wrote:Thanks for the quick reply Timmbo. I'm pretty sure I looked at the right plug. I'll look at it again the is weekend just to make sure. I went to the website you suggested and the FSM was not available for the 2013 Pathy.
It looks like you can purchase the "online subscription", but not the book???????????
mrbizzy
I purchased the subscription and found out that FSM is only available on CD for purchase and the price is $210.
Timmbo
You should get your $20 back!!!
mrbizzy
Timmbo,
My second attempt was successful!!!!
For anyone who wants to do this mod for the 2013 Pathy, its the TOP RIGHT plug if you were looking at the audio unit from the back. The pin layout for the plug is the same as the JX35 (just like Timmbo said). Look for the plug with the 16 pins. There should only be one.
mrbizzy
Thanks for the mod Timmbo!!!
Timmbo
EXCELLENT!!!!!!!! Success!!!!!!! You might have the first 2013 Pathy with the mod completed!!!
mrbizzy
mrbizzy wrote:Timmbo,
Actually its a 32 pin plug (2 rows of 16 pin). Sorry I couldn't figure out how to upload images.
Stitch79
Will this work and let me view movies on the nav screen if I do not have the theater package on my JX?
Timmbo
Yes!!! Sure will!!
jcao
Car: JX35
Why do you need a DPDT switch? Why not directly connect pin 53 and pin 70 to ground? Thanks :crazy:
griztkojr
Car: 2013 Infiniti JX 35
TIMMBO. First, thank you for the mod info. What is the best why to tap into the neccesary wires?
Timmbo
Cut and regular butt connectors for small wire is what I use.
ichibanb18c
Hey do you have a better diagram on how the wiring should go and what the switch looks like?
Thanks
Timmbo
That diagram works perfect! Very straight forward and easy. I did the mod on my new 2013 Maxima yesterday.
lgestrella
Car: 2013 PATHFINDER SV
Quick question. Why do we have to install a DPDT switch? its just a question.. i understand you can switch it back to Stock at any moment but from my understanding that's because IF you have a navi install the system feeds of the VSS to keep the right position of the vehicle. In my case i do not have NAVI... i just want to install a DVD player on either my center console box or glove compartment so i can watch movies or Music videos etc thru my Stock display... So if i don't have to install the DPDT switch HOW and CAN i do it.. thank you in advance guys.....
PS: i've been to some places and they all say i have to buy this Video In motion module to connect a DVD which cost almost $400!! can you believe that... that's crazy... i much rather do it my self and not spend all that $$$ on useless equipment..
lgestrella
after my last post i when ahead in took everything off and i have to tell you i was mad confuse lol... i disconnected the screen, the front plate and the Radio/AC panel off.. so what i tried to do was connected it to this plug that is the only 1 with 2 rows of 16pins located on the bottom left on the back of the unit.. i thought it was it bcuz when i turn on the car with the Ebrake on the screen for the video showed and when i disconnected that plug the screen would go back to normal setting... the color don't match!! i tried doing what you wrote and nothing.. looked at this AV manual i found and i could find the damn cable!! i ended up cutting the wrong one and just got frustrated and put everything back....
please help me out here guys..
: http://www.nicoclub.com/FSM/Pathfinder/ ... der/AV.pdf
i used this manual and i can not find the right setting or page i should be looking at let alone the plug.. please help! i have the SV model 2013 Pathfinder (Bluetooth/back up camara/sensors/RCA input) im trying to make it work where i can connect w/e i want thru the RCA input and watch it while i drive.....
Mayoo
Anyone here in GTA Canada wiling to help with this Mod for my JX .. I am bit nervous when comes to removing covers lol ..
Ualnosaj
Mayoo wrote:Anyone here in GTA Canada wiling to help with this Mod for my JX .. I am bit nervous when comes to removing covers lol ..
What's that? A group install day? :) I haven't got around to doing ours yet.
Timmbo
Easy install folks, takes about an hour!
lgestrella
yeah but we have the SV! the plug with 16 pins located on the bottom left, the colors or the locations of the wires (VSS & Ebrake) are not the same.. that's the prob timmbo
Mayoo
I found all the pics of each step from this post on wards .. very clearly shown here ..
Start from here
http://www.infinitijxforum.com/showthre ... #post10370
Return to “Infiniti JX35 / QX60 Forum”
