daniel240 wrote:ok, for the parts you had listed in your 1st post; are those just for the feed line, because it looked like you had 2 fittings and 1 hose? and does that include the "T" that you use at the oil sending unit?
yes sir .. the feed line itself has 2 fittings that are already assembled the 3-AN to 1/8 pipe thread. so realistically when you get it yuoull have 4 fittings
4092k11 1/8 NPT femal to 1/8 BSPT male $3.684468k401 3-AN (its listed as 3/16th i think) ss braided line with brass fittings 14-16$
50785K219 brass female by female by male brass T $ 0.93
1st one is the adapter from BSPT to NPT so you get the correct thread pitch for the oil pressure sensor hole
2nd one is the actual SS braided line with swivel fittings and connected are two 3-An to 1./8 NPT fittings *( what you screw into the turbo and one for the T )
and the last one is a brass T it has one female ( for the fittings on the SS line) and one female for the oil pressure switch and the male screws into teh adapter and into the block/
