SloS13 »
https://forums.nicoclub.com/slos13-u1021.html
Mon Oct 06, 2003 4:09 pm
I made a distribution block which is near the TB. The distribution block is fed by brake line, then splits to:1. dummy light2. autometer sender3. turbo feed (ss braided line)
I tapped my oil pan on the car1. Drill a pilot hole, allowing the natural shape of the bit to draw out 95% of the shavings
2. Used a UniBit to enlarge the hole
3. Used 2 cans of carb cleaner to push any shavings in the pan toward the drain plug.
4. Ran 8 quarts of cheap oil through the motor
5. replaced drain plug, cleaned oil container thoroughly
6. put in 4 quarts cheap oil, ran car for a couple minutes, drained the oil. saw metal flakes in oil
blah blah blah did this 3 more times, then waited 2 days then changed the oil again. looks great
waited 2-3 more days and changed the oil, putting good oil in it
