LOL... Now post those pics after it is doneEvillE423 wrote:I actually had some to put on and completely forgot to put it on. I'll run and do that real quick...haha. Thanks for reminding me.
Here we go. Just had the spray on foam. I thought I had the Black Magic Tire Wet in the trunk, but it's MIA at the moment, so this will have to do. Didn't turn out like I'd hoped.dee_tymz_sl wrote:
That's the mother-in-laws "green machine". It's a beast!Dasoupdude wrote:Looks Great
Moar pics of the escort too!
Fix'tZOMG.SR20 wrote:spray it on the rear tire tread and try to keep the car straight around turns
your as ghey as ottoreaper2022 wrote:
Fix't
Have you used a claybar on the car yet? Maybe it's just the pictures, but it seems like the reflection on the door should be a little sharper... how's the paint feel after waxing? Is it smooth or kind of gritty?
Fixed'd.ZOMG.SR20 wrote:
your as ghey as Tyler
Yeah, I've used a clay bar before. I was going to do it this time, but I didn't have any of that quick detailer that it gives you with the kit and I didn't know what else I could use. The paint is smooth. I've noticed that in places it's more glossy than others, like the hood for example. Who knows. Thanks for the compliments guys. The wax I've been using is about empty. What else is a good wax that's not to pricey?reaper2022 wrote:Have you used a claybar on the car yet? Maybe it's just the pictures, but it seems like the reflection on the door should be a little sharper... how's the paint feel after waxing? Is it smooth or kind of gritty?
Wow, a gay joke on the internet. Getting pretty creative there.ZOMG.SR20 wrote:your as ghey as otto
Mine has the engine cover on the bottom of it, so I don't think that's what it is. I have a small brake fluid leak, that's what made me think it was brake fluid.bcar240 wrote:That is a really clean car, kudos! I wish mine had aged that well.
If the stuff was on the front tires, it could be the same thing as what mine used to do. I had a small oil leak that was getting onto the crank pulley (or anything else that rotates) and was flinging oil all over the engine compartment. If you have the engine cover on the bottom, then you can probably ignore this, but since mine was never there, the oil was able to splash on the bottom inside of the wheels and work it's way everywhere. If that's not the case, it might just be some solution of brake-dust and water.
It may have very well been repainted. Some couple had it before me, so idk.PapaSmurf2k3 wrote:I was thinking the same thing with the glossyness... maybe its been repainted?
You've got a hamburger d!ck...
the foam is ok\krimsonviper wrote:Looking good man.
For the tire dressing, buy the eagle one tire foam applicator. You can make sure it stays on the sidewall and the dressing wont spray all over the place.
Thanks everyone!DRsr20Idet240FT wrote:car looks really clean!
