Was the SR your first swap?
S13FX
Car: '69 l20b Dimeski :)
Hey just wondering, Im gonna be doing my SR swap here soon, and Im by no means mechanicly stupid or anything but it is my first engine swap, but I have ripped engines apart, and rebuilt them before, just never put one in a car before heh. What should I prepare for?
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
Sometimes its a Pain to get the engine to line. And you have to wiggle it, and move it and stuff. You're not too far from me, if you need any help let me know.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
the SR into a 240 is very easy as swaps go, all the motor mounts and trans mounts line up, the driveshaft is good, the only difficult parts are getting the heater core and radiator hoses figured out and the wiring harness. http://www.heavythrottle.com has a great install runthrough and FAQ, http://www.nissanperformancemag.com also did a very good writeup on it. It depends though, there is lots of info for the S13 chassis but not so much for the S14.
S13FX
Thats aight cause IM doing the swap in to a '90 Hatch back heh. So its perfect. thx a lot guys
IanS
if its the SOHC model then your going to need to work somthing out with the power steering, either make the SR pump work, or find a pump off a DOHC KA and use the SR pulley.
Jesse SR20
Car: 1990 S13 fastback
My SR was my first Nissan swap.
My first swap was a 1600cc VW motor into a 59 Beetle. I was a senior in high school when I did that.
My 2nd swap was a B20z2 Honda CRV motor into my old 99 Civic hatchback. That was a fun motor.
And 3rd was the SR. It was super easy, just time consuming. A few words of advice; Get ahold of an engine leveler ! It was a biotch trying to get the motor mounts to line up with the subframe without one. After that, it's just wiring, which I'm totally comfortable with.
Henry G
Jesse SR20 wrote: A few words of advice; Get ahold of an engine leveler ! It was a biotch trying to get the motor mounts to line up with the subframe without one. After that, it's just wiring, which I'm totally comfortable with.
I'm getting close to putting the SR in, and thought I should pick up one of these. $20 whoo hoo!
IanS
hahahaha, I used a bobcat, a chain, and like 6 guys, I guess you can call me old fassioned, but it worked.
kane2g
Car: 92 240sx 95 240sx
if you want to give me a call, I'll try to stop by and help you out.email me at sirwarrior AT gmail.com
gpeele
Car: 96 240sx VH45 power
99 Chevy 1500 4x4 Z71
86 CMX450
one thing that made the heater hose thing much easier was the heavy throttle heater hose kit. you have to do some triming but i found it easier than using the stock hose and trying to get them to reach the usdm heater sockets on the firewall. its under the cooling system section on their sidebar. oh and make sure you get them pointing in the right direction before you bolt the motor in, theres very little space to mess with them once the motor is in.
another thing is that i found it easier to drop the entire drive shaft than to wrestle the yoke bolts loose. thats just my experience other people would disagree though.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
Well i am not doing and Sr swap but my first swaped motor was a 2000 chevy S-10 Xtreame with a 350 V-8now my baby is my S-13 with a RB25DET
