Want Bluetooth Streaming In Your M? Here's How!
tfs1975
Car: 1991 300zx Twin Turbo
2012 M37 Sport
Just wanted to give another update as far as troubleshooting the distortions in the drivers side tweeter. Since the last update this is what I have done.
1. I have downloaded a different music player on my phone and after messing with all the settings, I could not get the distortion to stop.
2. I unpluged the iSimple wire from the RCA side and plugged in a RCA to 3.5MM. There was no distortion when playing music this way. Started to think that it could be the iSimple causing the distortion.
3. I plugged the iSimple back in and hooked it up to my iPod Nano. It worked fine and had no distortion.
At this point, I think the distortion is due to the ANYCOM A2DP receiver. When I went back to the bluetooth the distortion was back. I am wondering if there is somekind of minimal distortion that can't be heard and is somehow amplified when using the ANYCOM A2DP. I have a friend who also has an ANYCOM receiver, I am gonna try his in the car and see if the distortion is still there. I am also trying to get my hands on a iPod speaker that I can plug the anycom into to see if there is any distortion.
Any other troubleshooting ideas are appreciated. Thank You
SmoovC
Car: '06 Infiniti M45 Premium, Brakemotive, H-Techs, KYB's, USA-Spec PA15-INFI w/ BT streaming, Kuda cell mount, Magnaflow exhaust. (CAR SOLD)
Current: 2012 Infiniti M56S, Harbour Blue, 4 pc Aero Kit
Sorry I haven't replied sooner, been busy trying to tie up ends at work before vacation. I think you have taken some steps towards troubleshooting the issue, but I am not sure that: if it is the Anycom, why it would not switch the distortion from left to right when you switched the RCAs at the USA SPEC. Although, plugging in your friend's Anycom would take any guesswork out of the equation. Did you plug your phone in with the 3.5 to RCA? I didn't see where that was clearly stated. If so, that eliminates the phone from the equation. It could also be the BT radio in the phone itself. Please update us as you progress.
tfs1975
2012 M37 Sport
Ok...My final Update. I tried a different ANYCOM Bluetooth receiver and to my dismay the distortion was still there. I had hooked up the RCA to 3.5mm to my phone and after listening very closely, I think I can hear a very faint distortion. I am thinking at this point that the USA-SPEC is the culprit and that somehow the bluetooth receiver seems to amplify it. I have decided to just use the RCA to 3.5mm and plug it into my phone. I don't think at this point that I can get another USA-SPEC to try out. The end result was to have music from my phone in the car and I have accomplished that. I would prefer the wireless but hey...it's better than it was.
Thanks
Se@ttleM35S
Car: 2006 Infiniti M35 Sport
SmoovC wrote:From the Owner's Manual:
"FM-AM-SAT radio operation
RADIO (FM/AM/SAT) band select:
Pushing the RADIO band select button will
change the band as follows:
AM!FM!SAT (XM/SR)!AM
When the RADIO band select button is
pushed while the ignition switch is in the
ACC or ON position, the radio will come on
at the station last played.
The last station/channel played will also
come on when the ONzOFF/VOL control
knob is pushed to ON.
The satellite radio mode will be skipped unless
an optional satellite receiver and antenna
are installed, and an XM or SIRIUSTM satellite
radio service subscription is active."
If you have Sat radio, you will get the preview channel, which is either 1 or the weather channel; 174 IIRC.
Hey SmoovC, I want to install a iPod Interface in my 06' M35 Sport. I don't have satellite radio, can you tell me if I need to use the PA15-INFI or the PA15-NIS? Thanks
tfs1975
2012 M37 Sport
@ Se@ttleM35S
I had done some research on this previously and from what I have learned, if you do not have Satellite radio you will need to go with the USA-SPEC PA15-NIS.
daverse
Car: 2007 M35X technology and deluxe touring package.
SmoovC wrote:Recently, I purchased a 2006 M45, and while I am impressed with the car as a whole, being an audiophile I needed iPod integration, and the ability to use my EVO 4G as a source of music.
Here's how:
1) I used (as many of you have) a USA SPEC PA15-INFI for iPod integration. I have satellite radio, so the interface was done in the trunk, and I mounted the module in the right kick panel. This was for ease of access for possible future upgrades, and to simplify running cables to the glove box. I felt this was the best location for said iPod, as it is lockable.
2) As most may know, the PA15-INFI has provision for an "AUX" input. To enable, you simply set dipswitch 1 to on. This will allow preset #6 to toggle the aux input. Using this input, we can now use a couple of parts readily available to create an A2DP Bluetooth connection:
3) You will need an iSimple IS76 cable. This cable has standard A/V RCA type connections and power / ground on one end, and an iPod connector on the other. Disregard the yellow video connector, as we will only be using the audio portion for this application. Plug the R/L audio connectors into the PA15-INFI aux in. At this point, you will need to provide ACC power to the cable. I found the easiest way to accomplish this was to pull the center console cupholder and tap into the cigarette lighter power supply. It is in a black nylon sleeve; brown is ACC power, black is GND, and red is lighting. Connect the red wire from the iSimple to the brown ACC wire, and the black wire from the iSimple to the black GND wire. I found it easiest to route the wire towards the firewall, around the footwell, and into the kick panel location.
4) Here is the part that makes this setup cool! An Anycom Bluetooth A2DP receiver. This unit simply plugs into the iPod end of the iSimple cable, and once paired to your phone, will allow streaming! I routed this cable and unit into the glovebox, and mounted with 3M tape to the location to the right of the trunk override switch. I wanted it in a visible location to be able to check the status of the connection, as it blinks a blue LED when paired and connected, solid when paired but not connected.
All of these units are readily available on the internet; simply search for them. This is a great solution for people who want iPod integration, and the ability to stream wirelessly from a phone. I am able to listen to Pandora Radio, Slacker Radio, and Scanner Radio, plus any music stored on the phone. Additionally, I can stream my entire iTunes collection from my home computer with a great app called Jam11.
In the event that you did not opt for the PA15-INFI interface, you may also use the rear AUX jacks on your vehicle, if so equipped. You will still need a power and ground connection, as the Anycom unit does require power to function.
I hope this helps anyone who needed a solution like this, and if you have any questions, feel free to post.
If I wanted to do this with an old iPhone like a 3g or a 3gs would I still need the anycom bluetooth a2dp receiver?
TXT
Car: 2006 M45 Sport
My 2006 already came with the iPod kit installed to the Satellite radio. When i hook up my iPhone i can see the song names displayed on the screen and all that good stuff BUT....I think i should be able to buy that Anycom Bluetooth receiver and connect it to the existing iPod connecter thats coming out of my glove box and not buy the RCA wires... right?
Another note, I can't find the anycom receiver anywhere online, i just see what seems to be some cheap ebay knockoffs.
If anybody knows where to get these let me know. Thanks.
joeyd-m35x
Car: 2007 Infiniti M35X
hello,
i have a somewhat basic question, as i am just starting to get information on this. My 2007 M35X has the aux port on the backside of the console. I have a cable that attaches the red and white to my Android phone(headphone jack), but how do i set the car source to use it? I have the Disk button, but it just cycles through DVD/CD. There is not Aux option. Any ideas?
jayfox911
Car: 2006 M35 Sport
joeyd-m35x wrote:hello,
I dont have those ports but to switch to my ipod I press the "radio" button. mine cycles through am/fm/sat/aux in
rxmclaren7
Car: 2006 Infiniti M35x
when you cycle through the dvd/cd "disc" options look in the lower left hand side of the screen there is a box that should be highlighted yellowwhen you are in the dvd play screen...it should say "settings/aux" click on that option and you will have the aux input you need to stream Pandora or MP3's from your phone or other 3.5mm head set jack!!
hope this helps!!
hsingh2088
Quick question, Anycom is no longer available.
Will this work?
http://www.amazon.com/gp/product/B0094G ... 7UY6AMKO25
L5211
Car: 2006 M45 Sport Diamond Graphite, Journey & Tech pkgs
I thought Bluetooth was Bluetooth. Now I realize that some older Bluetooth cannot stream music from my iPhone.
Can you tell me what to expect if I purchase a 2006 m45. What can the Bluetooth do? What can it not do that newer Bluetooth systems do?
I want to understand so I don't want to rely solely on owners word.
Blackzilla
Car: 2007 Infiniti M45, 2014 Mazda 6
I have the 2007 which i am sure is the same so I will tell you that mine can only make calls, there is no streaming feature for music. Infiniti technology was very slow. There is a thread on here where the user bought an Anycom receiver and an iSimple which is the only fix i've seen. Hope this helps.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
L5211 wrote:I thought Bluetooth was Bluetooth. Now I realize that some older Bluetooth cannot stream music from my iPhone.
Merged with existing thread. BTW, we have an incredible SEARCH feature on this forum.
L5211
Yes, I read all about the Bluetooth in Nico before my post. Just didn't understand a word of it LOL. Then again I just got my first smart phone a year ago. I still play CDs in the car, and pay cash for everything. I kept searching for this OTOH device until I figured out it meant on the other hand. I'm a dinosaur.
BigSexyNW_M
Car: 2007 M45 Sport - Custom Cat-Back - 20" Wheels - Lowered Suspension
Um- I'm confused :) :gotme
What do I need, if I just want to plug in my Android phone to a jack that will allow me to stream Pandora through my phone into the speakers?? :)
JOEYILO90
Car: INFINITI M35 06'
Question, if we dont have SAT (xm) option in our car (06' m35) where is this device suppose to be mounted?
JOEYILO90
Here's how:
what if you dont have SAT radio???? help please what is the best device to get i have a m35 06"
JOEYILO90
Hey SmoovC, I want to install a iPod Interface in my 06' M35 Sport. I don't have satellite radio, can you tell me if I need to use the PA15-INFI or the PA15-NIS? Thanks[/quote]
@ Se@ttleM35S
I had done some research on this previously and from what I have learned, if you do not have Satellite radio you will need to go with the USA-SPEC PA15-NIS.[/quote]
okay sweet thanks for the help! i have the same situation. hows the quality of the pa15? im looking to get JL audio will this devise do it justice?
BigSexyNW_M
What about Android? Are there systems that support Android? The USA-SPEC PA15-NIS is for iPod :(
Companionator
BigSexyNW_M wrote:What about Android? Are there systems that support Android? The USA-SPEC PA15-NIS is for iPod :(
You can get the BT45-INFI it lets you stream your music through a Bluetooth connection. My phone is a Note 2 and so far there haven't been any problems.
DrDad
Car: Infiniti M35
The information in here was awesome and worked PERFECTLY for my 2008 M35X that has an iPod tether in the center console. bluetooth-audio-streaming-for-2008-ex35 ... 89121.html
As alluded to later in the replies in that thread, the Scosche part of the setup is no longer necessary. All in all for the two parts, it was about $100 and required no skills for wiring - plug and play - and bluetooth works beautifully. The only negative with Android is that the digital info does not get to the center console, but full control via the steering wheel button is achieved, as is elimination of wires to the phones.
