VTC or to Not VTC with Poncams?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Going from OEM R33 to Tomei Pons and I am considering deleting the VTC. I would replace the pulleys with Tomei as well to allow for proper degreeing then adjustment via dyno. But after a bit of reading I am not so sure IE rb25-vtc-vs-no-vtc-t499476.html.
So poncams guys are you still using VTC, if so have you compared to without it. Also other than unplugging it, have any of you removed the solenoid completely?
This is for a GT30, AEM EMS R33 RB25 with more than enough supporting mods. Currently at 17psi it makes 385tq at 419hp
Carl H
r33 vtc is enabled from 1k-4.5k then it is off...somewhat narrow range and arguable if its helpful or not.
if you're going to be revving hard then vtc will become a hindrance, else you dont have too much to loose.
stock duration is terrible on the r33 motors so anything is better.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Yeah I am leaning on keeping it on and just dialing in the exhaust cam gear to see where it ends up. It's not a daily or close to it
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Don't know about the RB, but on my SR the VTC makes quite a large chunk of lower end torque... I have mine set from just off idle to 5.5k (around peak torque).
I know way back when I first started tuning my engine on the MegaSquirt, I started out with out VTC and when I enabled it, I was putting in about 30% more fuel where VTC was engaged.
Of course I daily drive my car, so driveability is somewhat important to me.
Of course VTC on the RB might be less important than my SR too, being a little larger displacement and 2 more cylinders.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I installed HKS cams with 264 duration and 8.8mm lift and found that raising the VTC disengagement point to 5200-5500 made significantly more low and mid range power and torque. Above that rpm, it didn't increase power. This was what I observed while on the dyno and was consistent through 3 separate sessions.
Carl H
you guys have any dyno charts for your motor?
i cant remember off hand how much advance the vtc system gives the cam, anyone remember?
bmxarmy
Car: 1961 AMC Rambler
I would like to know this too.... I am putting a new turbo, head studs and maybe a little more..... :chuckle: on the rambler this spring.
Being on mega squirt it would be easy to enable it for any rpm range....And I am already going to be in there to setup the 2-step/launch control.
I plan on leaning on it quite a bit harder this time around as dyno time is free thanks to a beauty friend, looking to run 24ish psi and maybe meth injection if iats start to climb to much. If I can gain a fair amount by activating the VCT I will..
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Carl H wrote:you guys have any dyno charts for your motor?
20 degrees from quick google search.
I plan to keep my NVCS on my NEO. Plan on gettin the Poncams aswell running Nistune
chad b.
Car: chocolate chip kouki
Kelford cams, hands down.
240z4u
Car: '95 Nissan 240SX
chad b. wrote:Kelford cams, hands down.
Start a new thread Chad. I'd like to hear more about them.
chad b.
Not starting a new thread, but I can say this about them: you can run a higher duration cam without them telling you to buy solid lifters, which is bullsh*t. I don't fall into that "if it comes from Japan, it's better" bandwagon. Plus, you can actually call and speak with the guys at Kelford and they can tell you from experience the outcome of using their cams verses Tomei's. Those guys at Kelford are really cool. I think the owners name is Kevin. PLUS, you can't run VTC with aftermarket cam gears, which you will want if you run aftermarket cams. That in itself should answer the OP's question.
RRRRB
Car: 98 RB powered S14
chad b. wrote:Not starting a new thread, but I can say this about them: you can run a higher duration cam without them telling you to buy solid lifters, which is bullsh*t. I don't fall into that "if it comes from Japan, it's better" bandwagon. Plus, you can actually call and speak with the guys at Kelford and they can tell you from experience the outcome of using their cams verses Tomei's. Those guys at Kelford are really cool. I think the owners name is Kevin. PLUS, you can't run VTC with aftermarket cam gears, which you will want if you run aftermarket cams. That in itself should answer the OP's question.
Im tempted to try something different myself..
My car makes s*** for power with the mods that are done to it.. im running tomei 260 10.25 procams wondering if they just suck?! lol out of ideas at this point
Carl H
have you checked to make sure your cams are in time?
and you never sent me your map to look over...
RRRRB
the cams are degree'd
I did send you the tune!!
Carl H
pm'ed you back!
240z4u
I have heard of Kelford Cams before. I would hope they would offer gains over Tomei since they are a lot more expensive. Thanks for the info.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
More money doesn't make better, but they do have some awesome profiles some a little too much for my needs.
