SpecDRacing »
https://forums.nicoclub.com/specdracing-u28175.html
Thu Sep 11, 2008 1:20 pm
NISMO240R
Very, very wicked. Love it, looks sick! Here's the secret to getting this thing running.
Power wires. Make sure all Ignition power to the ECM is definately IGN from the car. Make sure your back up power is on all the time. Wire in potentiometers (tps or whatever) to where the EVAP sensor should be, Refriegerant sensor and P/S sensor. Power the BCM as shown in the Service manual. Use a LED for the security light with a diode and wire it in the right way. Omit junk wires for ease of installation. Keep solid grounds. Make sure your NATS amp is plugged in. Make sure the Key matches the year of the ECM (not the BCM, Motor, etc.). DO NOT ALLOW YOUR BATTERY CRANKING VOLTAGE TO DROP BELOW 9V. There is a BIG reason for this. Durring this swap, you have to wire in a throttle relay like it is in the service manual (except its located in the IPDM-ER). If the cranking voltage drops below 9 volts, you will go into fail safe (not always, but it can happen). This will not be sufficient voltage to allow the throttle plate to move durring testing by the ECM and will cause a ETC Motor code, which is a fail safe code. So have a good battery.
There it is folks, the simplicity of the swap. It's all in the ESM. It takes a lot of time to wire, and a lot of patience, but if done right, will work.
04 ECM will have a idle with a 100% calculated load value, which will stall durring heavy deceleration without a little help from blipping the gas pedal. 06 ECM will idle high, but will not stall...but will also not advance the intake timing. My suggestion, send the 06 ECM to technosqaure, tell them what you're doing and have it mapped so that it will advance anyway (even though it shouldnt because the exhaust valve timing isn't hooked up).
Back to more fun. My latest project is just beginning. I cant post it all up on this thread, as it does not pertain to a S chassis car, but I felt you guys might like to see it anyway.
Yeap, thats my $500.00 beater. Even runs and drives. Sorta...the way reverse engages, it seams as though a teflon seal has failed causing a loss of pressure to the reverse clutch....but rev it up and she bangs into gear! Or, she did......but you guys all know me...and all that isn't even in the car anymore!
Yes, the hood is shut. No fiberglass, washers or anything. Whats under it fits, and will stay that way when the swap is actually performed/completed.
So there she sits. On mock up motor mounts and all. Not bolted in, but where it will be bolted in. The B15 guys have been doing this for a little while. I hear its pretty fast that way. So I figure I'll do it in a lighter car, complete with 4 doors to really confuse anyone who sees it go. It's getting a VQ35DE (sorry, staying stock), Sentra Spec V 6 speed (factory helical diff...thats awesome!), VQ35DE manual trans bellhousing, B15 front hubs/spindles, we hope the B15 axles will fit, but if not, we'll find what will, Altima front lowering springs and Sentra rear lowering springs. Tokico shocks that will match my bound/rebound requirements and hopefully some Brembo brakes. But the steel 14" wheels...well, they gotta go (darn) but some equally cheezy wheels will be installed in their plate. Maybe some aerospeed wheels with hub caps!!!
Later gang!
Modified by SpecDRacing at 5:53 PM 9/11/2008
