Really, I know what the knocking is (only when its cold right, in the morning)? And the battery dieing in a week is due to the wrong 12V supply wires being used. The wiring diagrams in the S13 manual are wrong for a few of the source wires. They are on constantly, even though it shows them to be only on with the KEY. I actually did this mistake on the first VQ35 swap I did, and it had to be corrected.
As for my updates, its been slow. Just been driving the car and working. I havent even gotten the speedo or tach in yet....or the 04-06 ECM (automatic) that I got for it. I did manage to put it on the dyno.
250HP at 6500 rpm (not that impressive)250 lb/ft torque from 1800rpm all the way through 6800rpm (that IS impressive).
Plans are in the works for a much better exhaust, as it can be seen that it is very restrictive, especially with the Maxima muffler. Probably losing 25 HP from that. The ECM needs to be changed to get the 30-40 HP Im missing not running IVT. I've just havent had the hour of time to swap it. The Air/Fuel was way too rich too, about 11.5:1, which means either I drop the fuel presure some, or I add a blower!
> May do that.
I did find something new you guys might like. The Sentra SE-R Vspec (new model) comes with 8" and 3" rear deck speakers. This is from the Rockford Fosgate system. They are both on a housing and there is one pair per side of the deck. Now either these speakers are REALLY cheap, or NIssan messed up pricing them, but I got them for $12.00 each. I put them in all four corners of the car (total $55.00 in speakers). I ran all new speaker wiring from a Sony 4 channel amp (cheapo from Walmart, about $100). It sounds good with the 10" in the rear too, but still needs some work. Heres a few pics.
Thats the front door. I had to trim one of the ears off to get it mounted and remove an edge in the door. I will need to make a 1/2" spacer to fit behind these to bring them out enough for the window to fully go down. Then I will need to trim the door panel and extend the grille area to acomodate for the larger speakers.
This is the rear deck. My interior here was pretty shot, so it was no big deal to toss it. I will need to lay carpet down and build a grille here as well. The openings for the factory speakers only had to be cut in (towards the center of the car) by about an inch to allow for the wires to pass through.
Here's the amp all tucked in under the passenger seat. This is with the seat in the full forward position. Please excuse me for the mess in my car......we all know how project cars go though! I wired the speakers to be 6 ohms each for clarity. Im not completely happy with the 3" speakers up front, so I will remove them and in stall some 5 1/4's higher up in the door. Once thats done, and all the panels are made/modified, I should have a pretty good sound system for cruising.......which again, was my goal with this car.
Maybe one day I'll have the money for a corvette, but after I'd put all this time into this car....would I want one???? What am I thinking, hell yeah I'd want one!
Later gang!
Modified by SpecDRacing at 6:12 AM 1/27/2008
