SpecDRacing »
https://forums.nicoclub.com/specdracing-u28175.html
Fri Jan 19, 2007 2:44 pm
Correct, the great thing about this swap is the immediate power gain, the lowering of the vehicles total weight, the added benefit of greater gas mileage (stock 300HP computer with 32 mpg...awesome), an extra gear for highway cruising, costs less than an RB26 swap, is a quarter mile monster with the stock rearend or even a 4.3 from an Xterra, all parts are available here in the states (no need to go overseas for a basic part), and last of all, complete sleeper.
As for this 240sx, it will be recieving the good ol' J30 rearend (3.91 ring and pinion, LSD). The stock 4.08 gear is a bit short for daily driving on the street, and the 3.91 from the J will be perfect......especially since the Z guys pay over $1200 for that ratio installed to their 350's (again, stock 350Z is 3.6). But all of this is useless at this point because...........................................WE ARE STILL WAITING ON THE DRIVE SHAFT! Can you guys believe this???? It was ordered 3 weeks ago, got the wrong one in from this particular junkyard, and they havent sent the correct one yet. Soon there will be a chargeback and a brand new driveshaft may get ordered from Nissan. Our cost is only like $180.00.
BRAKE BREAKTHROUGH:!!!!
FOR YOU GUYS WANTING TO UPGRADE YOUR BRAKES, I HAVE FOUND A NEW SETUP THAT IS EXTREMELY CHEAP AND WORKS GREAT!!!
We all know about J-30 front rotors and calipers. Big woop. IBut what about the rear???? Nope, nope, dont go to the junkyard and buy the entire spindle from a 300Z only to add weight to your car for a parking brake, I have a way to fit the J30 rear rotors to the 240SX and still retain the stock parking brake system.
The story is, I purchased the J30 front calipers and rotors last week for my 240 (to the new guys, this is another car, not the one with the VQ). I redrilled the rotors for the 4 lug pattern and installed them to my car......cool. But the rears needed upgrading as well. So back to the junkyard I go. I wanted to use the J30 rear rotors because they are vented and about 2" larger than the stock 240sx solid rear rotors. I know that the rear caliper bracket bolts directly to the 240sx and has the correct offest for the J30 rotor. What I didnt like was the loss of use of my parking brake cable....most people swap the entire rear 300z/J30 setup to get the drum style parking brake. This weighs too much and though it does lock better, its overkill for what Im building. So here I sit, in Pull-A-Part with a 240 (1990) infront of me, three of the four lugs knocked out, the 5 lug rotor on the 240 (from the J), the caliper bracket from the J30 and no caliper to use that has the parking brake function. I rumaged through the parts yard for 3 HOURS looking at different calipers and finaly came up with a combination that works.
Rear J30 Rotors drilled to a 4 lug pattern Rear J30 Caliper BracketsRear 1991 Maxima CalipersRear 1989 Maxima Parking Brake Cable Cam (spring loaded on caliper)Rear J30 Brake Linings (Pads)
To make it all work, I drilled out the slide pin runs on the J30 caliper brackets with a 25/64 drill bit (I think, I may be wrong...10.5mm is the target here). This allowed for the slide pins from the 240sx caliper brackets to be used (the 240sx/maxima uses two 14mm bolts, bolting through the caliper to the slide pins where the J30 uses a slide pin that threads into the caliper...just trust me, they arent compatible). After that was done, the calipers (MAX) need to be correct for the parking brake cable. The origional parking brake cable cam is positioned the wrong way on the caliper. I replaced those with the ones from the older max that can be used with our cables (the newer ones use a eyelet style were ares attach like a throttle cable). By changing that cam, I can hook up our cable to the caliper. The left rear Max caliper is used on the right rear of the 240 and the left rear 240sx parking brake cable bracket (protruding from the caliper) is used on the now right rear caliper (max). The cable wraps around the parking brake cam after its all installed, but its doesnt affect operation much. Now that you have your Maxima calipers on your J30 caliper brackets with the older style Maxima parking brake cams, you can bolt all this to the spindle of the 240sx and WHALAH, big brake upgrade for the rear of your 240 and still maintain the stock cable system.
Within the next few days, I will do another thread showing how all of this goes together and I should have a correct parts list for you. In case your wondering, somewhere around 1990 they changed the Maxima caliper, it used to have the mounting ears closer to the piston. The J bracket is approximately 1.5" wider than the stock 240sx caliper (and older max). That is why so many different parts must be used.
End result, well, lets just say that I can do 100 into an interstate offramp, begin the turn (cloverleaf type) and be slowed to 30 mph before I reach the apex. Wicked....period. Now I know I can stop all that motor im about to put in here.
Later gang!
