VMR 710 or ENKEI
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Gman56
I was looking to get some VMR 710s or ENKEI rpfo1? 18" hyper silver for my audi but since Ive switched to Infiniti which ones will look the best on her?
joe603
Car: 2014 Durango R/T
PICs of the rims?
audtatious
I prefer the look of the VMR 710's but it's all dependent on the car and the drop.
Gman56
They will go on a 05 G35X sedan stock suspension.I will go to 18" from 17".I might drop it maybe an inch.The VMR are alittle cheaper.I will be looking to switch in the spring.
audtatious
18" is good, 19" would probably fill the wells better. Make sure you get a good offset wheel.
Gman56
Stock offset is 45?I want to be as close to flush as possible.Do the 19s bend easy? Im a former Audi a6 quattro owner . On the audi forums they say 19s bend-warp to easy.I dont want spedo to be off by to much.Infinitis are alot faster 6 cyl .Dont need any speeding tickets lol.I was going for the VMR 710s on my audi until I drove a Infiniti.I had to get the G35x once I drove her!
audtatious
Nothing wrong with 19's. I'm running 20's and have hit some hellatious potholes.
Here's a thread that has factory wheel size information and what offsets you can go with:
g35-g37-oem-wheel-specifications-after- ... 42067.html
Gman56
Thanks for the info!
Kevvsworld
Car: 2006 Laser Red G35 Coupe AT
V710's or Avant Garde M310's are beautiful on a G. Per the dealer rep I talked to recently, 18" M310's can only be had in Dolphin Gray. You'll need to have them powder coated if you want a different color. And I've only found the VMR V710's in a 19" wheel for the 5x114.3 offset. If you have a source that has them in 18", please do share :)
Kevvsworld
audtatious
Similar to my Forgestars.....
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
