G35 Coupe Wheel Offsets
OEM wheel specifications:17" wheels Front: 17x7.5 +30mm offset Rear: 17x8 +33mm offset
18" wheels Front & Rear: 18x8 +30mm offset Weight: 23.5lbs
19" wheels Front: 19x8 +30mm offset Rear: 19x8.5" +33mm offset
Commonly used after-market offsets:Very Aggressive:
Front width: 9.5" +19mm offset Rear with: 10.5" +17mm offset
Aggressive:Front width: 8.5" +20-22mm offset Rear width:9.5" +22 mm offset
Most common tire sized used 245 series front and 275 rear.
G37 Coupe Wheel Offsets
G37 OEM Wheels Specs Sport Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43 Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45 Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
G37 non sport Front & Rear 18x8 +43mm offset
Commonly used after-market offsets:Front width: 8.5" +30-35mm offset Rear width: 9.5" +30-35mm offset
*NOTE: G37 and G35 coupe offsets differ completely. G35 coupe offsets are way to aggressive for the G37 and will not work*
G35 Sedan Wheel Offsets
1st GEN G35 Sedan OEM Wheel Specs Sport Model (2003-2004) & Non Sport Model Front & Rear: 17x7 +45mm offset Weight: 23.2lbs
Sport Model (2005-2006)Front & Rear: 18x7.5 +45mm offset
Non Sport Model (2005-2006)Front & Rear : 17x7 +45mm offset
Commonly used after-market offsets:All first Gen years Front width: 8.5" +29-30mm offset Rear width: 9.5" +35-40mm offset Rear width: 10" +42-45mm offset
245 series front tire and 265-275 rear tire are most commonly used
2nd GEN G35 Sedan OEM Wheel Specs
2007-2008 17" wheels Front & Rear -17"x7.5" +45mm offset
2007-2008 18" sport wheels Front: 18x7.5 +45mm offset (appx 23.7lbs)Rear: 18x8.5 +50mm offset (appx 22.4lbs)
Commonly used after-market offsets:*See 1st GEN G35 Sedan after-market offsets*
***NOTE PERTAINING TO AWD SEDANS FOR EITHER GENERATION*** (IT IS NOT RECOMMENDED TO RUN STAGGERED WHEEL SETUPS AS IT MAY THROW OFF THE VDC)
*NOTE: With all after-market applications, rear fenders may need to be rolled to prevent rubbing issues depending on suspension setup and tire size*
G37 Sedan Wheel Offsets
2009+ 17" wheels Front & Rear -17"x7.5" +45mm offset
2009+ 18" sport wheels Front: 18x7.5 +45mm offset Rear: 18x8.5 +50mm offset
G37 Convertible Wheel Offsets
2009+ Base wheels: Front 18x8 +43mm offset; Rear 18x8.5 +27mm offset
2009+ Sportwheels: Front 19x8.5 +43mm offset; Rear 19x9 +30mm offset
