I think that was szhosain that helped you. But I will still be happy to take a ride in it once its done if I ever make it down there.kscherbaum wrote:Moderator, thanks for the help ! You get Shotgun ! Looks like you live in So. Cal... If you are ever down San Diego way and the Buggy is done I'll take you for a ride you will never forget !
Thanks !
-Kurt
any pictures of those wheels and/or sensors?kscherbaum wrote:Already designed and water jetted out a 180 tooth crank trigger that bolts to the Flywheel and I am in the process of designing the Cam Trigger that will bolt to the rear of one of the cams with a mag sensor...
-Kurt
