neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Tue Jan 22, 2008 5:17 pm
plx smafr on narrow band same thing they state will be a cheap and highly accurate setup... hasnt let me down in a couple years lol.
funny you say that, it was my plan to get some 370's my freind has for 75 bux, turn pressure down to about 55 plus boost. A walbro hp is desighned to be at higher pressures, I am thinking my pump is from the chinese knock off set, 90% of the people using them are not ever seeing 60psi or more.
I'll give leaning it out a shot, but I still dont think the pump is workign in proper fashion, pressure should be steady at idle not bouncing all over the place. vac is SOLID around 19. I mean a 8psi or so bounce is a lot imo.
