neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Wed Jan 23, 2008 6:02 am
tps is set to .5,maf is about 1.8 at idle, I do have a wideband... the gauge however is a narrow band(it works man I've used it for like 2.5years now,tuned the sohc n/a de and the turbo de with it...) I'll see what my tps does on the meter again I didnt check to see if the transistioning to and from wot were smooth I can always toss on another one, you think a sohc tps will fit I kow I have one floating around here? yeah I tuned it myself, and timing is a bit low, but should be usable. I'll try taking out a tad of fuel then add a couple degrees. I really have tried almost everything besides buying stuff, I'm going to go buy a new filter(this ones like 3months old tops)
